Sound of stage III cams
check out steve's signature, it lets in on a few details of the combo....
06GT
Powerhouse 76mm turbo @ 22lbs
MMR 302 stroker
Livernois stage III heads & IIIspr cams
FB Performance 4r70w, transbrake
Lethal Perf triple fuel pump sys, 80lb inject
JPC intake manifold
meth sys, 9"rear, spool, drag susp
Bogart 15" wheels, MT slicks, skinnies
NHRA cert 10 pt cage
old times before latest mods & engine rebuild 10.0 @ 136mph
:jaw:
What does it dyno?
That was car idling just after finishing engine rebuild and installling mods. Car is at tuners now. They will likely play with the idle for a while before it goes on the rollers. Dynotuning probably won't start until next weekend. Then datalogging and suspension tuning at the strip. Then maybe more dynotuning. Whatever the tuners want.
Used to be dynoed on a Dynojet rwhp was 680 and rwtq 735. That was a while back though. Now we use a mustangdyno and numbers will be different. Don't really pay much attention to dyno numbers anymore (don't post in sig). It's a tuning tool. Just want to generate more power post than pre-tuning....and safely.
Car is not used for transportation anymore and we are considering doing whatever is necessary to drop 500+lbs weight. Can only guess what times might be. The 10.0 was with modest timing, car sputtering, dying during staging and with fouled plugs.
