Spacers need lug cutting?
  • Thread starter Thread starter LaserSVT
  • Start date Start date Feb 25, 2008
LaserSVT
3,548
233
Feb 25, 2008
  • Feb 25, 2008
So I was looking at getting one inch spacers for the rear wheels but not if I have to cut down the stock lug stems. Does anyone know if they have to be shortened for 1" spacer when using the stock Cobra wheel? Guess I could pull off the wheel and see if there are holes between the lug holes but thats too much work
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Feb 25, 2008
  • Feb 25, 2008
um, youre gonna need longer studs with that big of a spacer, unless you get the bolt on kind, which are designed to be used with the stock wheel studs.
LaserSVT
3,548
233
Feb 25, 2008
  • Feb 25, 2008
Ug......yeah 1" spacers bolt to the car then have new studs on them with the stock studs recessed inside of the spacer. I needed to know if the stock studs are longer than an inch and if so do the stock wheels have holes between the bolt holes for the stems to stick out into.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Feb 26, 2008
  • Feb 26, 2008
well you can stack smaller spacers if you have longer studs. which ones are you getting? i would think they would be designed with stock studs in mind.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Feb 26, 2008
  • Feb 26, 2008
Yes....from what I remember, the stock Cobra wheels (and pretty much any factory Mustang wheel for that matter) have recessions between the lugs to accept the ends of the old studs.
LaserSVT
3,548
233
Feb 26, 2008
  • Feb 26, 2008
They are and some say MAY need trimming and some dont say anything. They will be hubcentric for rangers and explorers too, so many different wheel options.
The ones im looking at on ebay are $70 shipped and 1" 6061 Billet with 1/2" studs and lugnuts. They are also hubcentric.
LaserSVT
3,548
233
Feb 26, 2008
  • Feb 26, 2008
Cool thanx gearbanger, I keep telling everyone Canadians are useful
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Feb 26, 2008
  • Feb 26, 2008
On rare occasions, we come in handy.
If worse comes to absolute worse, you could always replace the stock studs, with shorter ones. Wheel studs aren't all that expensive to replace
I personally think you'll be alright without having to change studs though. The little bit of "nub" at the end should be recieved but the holes between the lugs on the stock wheels.
Serper3
120
Sunnyvale, Ca Bay Area close to san francisco
Feb 26, 2008
  • Feb 26, 2008
i just got the H&R 1" spacers and the stock studs are barely longer and my saleen replicas had no issues with it and i had to do no cutting whatsoever. i was told by many though not to cheap out and go with mm or H&R etc.. just letting u know though lol
J
Wheels-Tires Need Some Help - Brakes Upgrade/Wheel fitment
  • jaygee15
  • Dec 8, 2025
  • 3 4 5
4K
Fox 5.0 Mustang Tech Oct 6, 2026
jaygee15
J
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
N
1969 15x10 295's for rear. Modifications needed?
  • normg
  • May 1, 2026
1965 - 1973 Classic Mustangs -General/Talk- May 2, 2026
GypsyR
G
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
