Spare Tire options
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Being that, for whatever reason, the prior owner of my 'Stang elected to keep the spare tire and all related bits n' pieces, I'm trying to come up with a suitable solution to my lack of a Plan B, so to speak. Not keen on the idea of taking a car outside of town (especially in the desert) without a spare, y'know? Thus, I have a couple of options:
1. Hunt the boneyards for a plain ol' donut spare (no luck finding one yet);
2. Snag one off of eBay and pay more for shipping than I would for the spare, itself;
3. Get a full-size 15" rim, mount up a proper-sized (225/60/15) tire on there, and not have to worry about rotating 'em around if one of the rears goes flat to avoid ruining the limited-slip;
4. Start up an account with AAA and hope for the best. :D
Problems are (respectively):
1. Having to swap around tires if a rear goes out, which involves twice as much lifting/lowering and such, plus I'm not sure if the OEM donut spare is 14" or 15" - maybe one out of a four-lug T-Bird or Cougar?;
2. Same as above, plus I hate risking getting scammed on eBay;
3. Not sure a full-size rim/stock tire would fit in the trunk well without taking up the whole darned area;
4. What good is AAA when there's zero cell phone reception when you're stranded out in the middle of B.F.E.? ;)
Any ideas/suggestions/magickal solutions?
any 4 lug donut would probably work since you'll only have it on temporarily...not supposed to drive over 50 miles on it.
Shipping on one from ebay should only be $15-20 really. I got a 15x10 draglite w/ 275/60/R15 tire shipped for $25 Florida to Missouri
call local junkyards you can usually get a spare rim minus the hubcap(LOL) usually with a decent tire already mounted for about $25 it should fit in tire space in trunk if its a 195or205 but check before you buy it this is what my son did.
Ah! Good point about the brakes. Never considered that part before. Car's always been a V8 model, so yeah, I guess it'd have to be a 15", then.
'Kay, so that zaps the 14" spare rim options. I suppose maybe I could always hunt down a couple of those fancy aluminum Cobra spares that I've seen here and there on eBay, mount on some skinny Mickey Thompsons, and use those for the track while keeping one full-size for a spare, and then swapping one of the skinnies into the back if I get a flat during regular driving...?
Anyone know if a full-size tire/rim fits under the spare tire panel in the rear? I could drop a tire of mine in there to test it, but I don't have a replacement spare cover yet to verify the height and such...
My '88 SSP car has a full size spare but it does make a bump in the trunk. The SSP trunk carpet is made to go over the bump and it has a little cardboard insert over the inner wheel of the spare. Of course it's a notch so it doesn't show. Damn shame you aren't in FL, I have an extra steelie spare with a near new tire you could have. I went looking for one for my son's '93and found several in my area. Call around and look a little harder, there has to be one somewhere nearby!
Been contemplating a set of 15" turbines I found at a yard. I figure I could use one or two for spares, then have the other two handy for slicks or maybe just some extra-wide radials. They're wanting $100 for a set of four, though, and once I factor in the cost of another tire(s), it becomes a tad pricey ... plus this set didn't have any center caps. :(
Mayhaps I should just look into a set of 16" ponies and just hang onto my current 15's as spares...?
