Speedometer Not Working
  • Thread starter Thread starter Sompin2do
  • Start date Start date Jun 23, 2006
Sompin2do
59
TX
Jun 23, 2006
  • Jun 23, 2006
Just replaced my heater core and evaporator core so I had the dash back far enough to get the box out. Now that I have it all back together the speedometer isn't working. Last night I pulled the instrument cluster back far enough to see that the speedo cable is still connected. Can somebody tell me what I might have done to cause the speedo not to work?
Thanks!
Flavadave4
1,044
21
49
Utica, NY
Jun 23, 2006
  • Jun 23, 2006
You might have pulled it apart inside the tranny where the speedo gear is attached to the cable?
88Stang331
239
  • Jun 23, 2006
unlikely seeing as it is held in by two metal clips.
Sompin2do
59
TX
Jun 26, 2006
  • Jun 26, 2006
Climbed under my car yesterday and nothing pulled loose at the tranny. One thing I did notice is the shielding around the cable has pulled back around the connection at the back of the instrument cluster. I'm at a loss here.
I'll be taking it to a shop later today to have the new R134 charged so I may have them take a look, but I hate not knowing.
Thanks!
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 26, 2006
  • Jun 26, 2006
Thanks!
That may give some extra slack in the cable so that the tip does not engage the speedo drive.
Sompin2do
59
TX
Jun 26, 2006
  • Jun 26, 2006
Now that makes perfect sense. It does seem like theres too much slack. Is the speedo cable on an automatic tranny with cruise a big deal to change? What would be a WAG for how much a shop would charge? Since the car will be there already it may be worth having them do it. Thanks!
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 26, 2006
  • Jun 26, 2006
Speedometer cable replacement for 87-93 Mustangs.
Note: All 89-93 cars have a VSS sensor even if they do not have cruse control. The 87-88 only have a VSS sensor if the have cruse control.
Speedo cable housing assembly without cruse control:
Speedo cable housing assembly with cruse control
1. Inside the car:
1.) Remove the shield around the steering column that covers the ignition switch & turn indicator switch.
2.) You now have access to the two screws that hold the lower part of the cluster housing in place. Remove them and place them in a zip bag.
3.) Use a stubby or an offset Philips screwdriver to remove the two screws on the top of the cluster housing. The screws are up close to the windshield, so they can be hard to get at.
4.) The cluster housing will now slide forward: depending on your particular car, you may or may not have to disconnect the wiring for the headlights, hazard lights, or cluster wiring. All of the wiring uses plastic connectors with plastic spring clips on them. To release the connectors, lift the plastic clips and pull straight back.
5.) The speedo cable is secured in the speedo head by a white plastic clip. Depress the clip or squeeze it and pull the cable out of the speedo head. This can be tricky, but it will come out if you have the white clip depressed enough.
6.) With speedo cable removed from the speedo head, try twisting the cable end with your fingers. If it turns more than 1/4 turn, the cable may eiter be broken or you have damge at the other end where the cable mates to the VSS sensor or speedo pickup gear in the transmission.
Outside the car, replacing the cable housing assembly. The following steps are necessary only if you plan on replacing the cable & cable housing assembly.
7.) If you are going to the replace the cable housing, the next step is important. Tie a study string or wire to the VSS sensor end of the cable housing. This string or wire is to be used to fish the cable housing back through the maze of wires that is under the dash. If all you are going to do is replace the inner cable, you can omit this step.
8.) Jack up the car, all 4 tires must be off the ground. Place jackstands under the car for safety.
9.) Locate the VSS sensor on the driver’s side of the transmission tailshaft housing. The speedo cable housing will be secured in the VSS sensor with a hairpin clip Do not remove the clip!!!: The hairpin clip stays in place. If you remove it, the odds are that you will not be able to get the cable to stay in place on re-installation. Pull firmly straight back on the cable housing and it will come out. A considerable amount of effort may be required to get the cable out of the VSS sensor, but it will pull out.
10.) Release the cable housing from the clips that secure it to the car body.
Inside the car:
11.) The housing assembly can then be pulled out and the fish string or wire can be removed from the old cable housing and secured to the new one.
12.) The inner cable can be removed by pulling it out of the housing assembly. Watch out for the lubricant so that you don’t get it on the car’s interior.
13.) Lubricate only the lower part of the new cable with speedometer lubricant or graphite. Don’t use too much lubricant, or it will work its way up into the speedo head unit and damage it. Thread the inner cable into the housing, turning it as you go. When you are all the way in with the new cable, it will engage the VSS sensor and stop turning.
14.) Use the fish string or wire to feed the cable housing assembly through the dash wiring and out the cable hole in the firewall.
15.) Secure the cable in the body clips, making sure that the cable isn’t rubbing against the exhaust pipe.
16.) Push the cable housing assembly into the VSS sensor until it snaps in past the hairpin clip.
Inside the car:
17.) Push the cable housing back into the speedo head unit. You should be able to feel the white clip click into place.
18.) Reconnect all the wires & connectors on the speedo head unit.
19.) Re-install the cluster unit in the dash & tighten the 4 screws that hold it in place.
20.) Re-install the cover for the ignition switch & turn signal.
21.) If the car is up on jackstands, start the car, place it in gear & watch the speedo to see if it works OK. If you didn’t jack the car up, take a test drive.
Sompin2do
59
TX
Jun 26, 2006
  • Jun 26, 2006
Sweet! Thanks very much!
riceslayer302
Banned
Oct 3, 2006
CT
Jan 25, 2007
  • Jan 25, 2007
Jrichker, your the man
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
J
Speedometer cable
  • Jimwbx
  • Sep 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2025
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
D
Engine Coolant and Radio Issues
  • Don7Up
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 4, 2025
Don7Up
D
