Spring Question
  • Thread starter Thread starter snoboardcore
  • Start date Start date Dec 20, 2005
snoboardcore
276
New Hampshire
Dec 20, 2005
  • Dec 20, 2005
Hey my car is going to be a track/street car more track though. What would you guys recomend for a good drag/street spring?
1SLO306
My 97 GTP owns you ALL!
Mar 31, 2005
904
Muhlenberg, ky
Dec 20, 2005
  • Dec 20, 2005
i would look in to just drag springs. also good to look into drag shocks too!
M
Mike92GT
583
Florida
Dec 20, 2005
  • Dec 20, 2005
I'm using the Eibach drag launch kit in my car with lakewood 70/30 struts in the front, and Tokico adjustable shocks in the rear. It drives great on the steet, and there was a noticable improvement in traction as well. If you want to get the most out of a set of drag springs, you really need to remove your front sway bar. The downside of this is that you lose a lot of your ability to take corners, due to increased body roll. The up side is you greatly increase weight transfer to the rear wheels.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Dec 20, 2005
  • Dec 20, 2005
Mike makes a good point about the sway bar. It is a easy thing to remove and reinstall. only 4 bolts and 2 link bars. I have been told that for drag racing you can just undo the driverside link bar and besides the weight saved by removing it it works just aswell as removing. I don't have a drag racing suspension set up at all. I have Ford Racing progressive springs and KYB struts and shocks. Off the juice i get 1.8 to 1.7 sixty foot times on it i get 1.6's mind you i do use slicks.
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
3K
Fox 5.0 Mustang Tech Apr 11, 2026
Brake Fluid shelf life?
  • Bullitt347
  • Sep 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 29, 2026
nickyb
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
