SSI-SERIES INTAKE MANIFOLD?
  • Yes!
    Votes: 4 33.3%
  • NO!
    Votes: 8 66.7%
  • Total voters
    12
should i get one?
• Adds 18-35 horsepower over the factory manifold
• Features unique open runner high-flow lower manifold
• High torque twin plenum upper intake
• Standard high-flow aluminum fuel rails included
• Standard 75mm throttle body opening
• Built-in EGR spacer
I say if you have the stock intake on now then ya give it a try, but if you have an after maket intake already on you arent going to see any huge improvements in power for the money spent.
ls1beater4eva said:
for the price of the bbk go with the tfs heat intake or even the holley, bbk has tomany issues with there products, juist look at the other bbk post to see some of them in here.:D
This is very true, my friend is in the process right now have to send his back, because the missdrilled holes in the intake of the TB we dont know yet, but from what i hear there are many times that thing dont work out, because of their crappy quality controll....
-AJ
-AJ
ohh ok thank I think I will get tfs heat intake :)
In the MMFF article, if I remember correctly the engine wasn't very matched so it did show some good gains but wasn't a very good comparison at all. It totally skewed the results. THe cobra/GT40/Explorer(pretty much the same) intakes are good intakes. A really good one for a fairly stock engine is an edelbrock IMO. It Has a 70mm TB opening unlike the cobra and porting shows good results later on when you get heads. Unless you have heads too I would stay away from TFS and Holley.
Kevin
