  • SN95 4.6L Mustang Tech
Stage II cams?
  • Thread starter Thread starter scupking
  • Start date Start date Nov 23, 2007
1 of 2 Next Last
scupking
1,186
Enfield, CT
Nov 23, 2007
  • Nov 23, 2007
What stage II would not lose much low end torque. Crower stage II seems good but how good are comp XE270s and what spring should I get?
superstang01
448
9
29
Kingston, On, Canada
Nov 23, 2007
  • Nov 23, 2007
i am curious about the crower stage 2 cams aswell, i have not really seen any results from them
R
r3dn3ck
39
  • Nov 25, 2007
the crower stage 2 I last saw the specs for was a helluva mild cam. I'd call it a minor change. the 270 is closer to what crower calls a stage 3 cam.
Get yourself a custom grind from comp. It's the same cost and always a better result.
M
mineralgraygt
187
nj
Nov 25, 2007
  • Nov 25, 2007
get the blower cam. i have the stage 2 crower blower cam they are 571 lift and 234 234 duration at .50 thats what im running in my car and i love them great cams i also running there valve springs they are good until 600 lift
Night Shifter
Well-Known Member
Dec 24, 2005
1,710
27
59
Daytona
Nov 25, 2007
  • Nov 25, 2007
Don't get blower cams unless your plannig on going S/C. You'll end up losing more power since they are made for having a power adder. They will sound good and pull hard but if you want your cams to be sound and performace go with the 270's
T
TGJ
1,049
  • Nov 25, 2007
I am getting tired of constantly correcting this Bull**** theory. One of the best N/A cams out there is the Comp 270, the Crower Stg 2 PI SC cam is almost identical to it with the exception of having more lift. It too works extremely well N/A. I am using the Crower Stg 2 PI SC cam in a N/A car that will never see a SC and am having great success with it. What one company considers a blower cam, another company has a N/A cam that is similar spec'd to it and vice versa. What matters most is the cam specs...
Just to show something here, I am posting the Comp 270 specs and Crower Stg 2 PI SC specs:
Comp 270:
234/238 @ .050", 109/117 113 LSA .550" lift intake and exhaust
Crower Stg 2 PI SC
234/234 @ .050", 110/118 114 LSA .581" lift intake and exhaust
scupking
1,186
Enfield, CT
Nov 25, 2007
  • Nov 25, 2007
Comp 270:
Crower Stg 2 PI SC
Do you have any sound clips? The only other thing I would need are springs right?
2002VertGT
15
Madison, WI
Nov 26, 2007
  • Nov 26, 2007
Just two quick questions:
What are the stock #'s on my 2002 cams?
How much do Comp cams run?
T
TGJ
1,049
  • Nov 26, 2007
I had clips of my car and can't find them anywhere...
All you need is springs if you have PI heads.
Stock PI cams
200/209 @ .050", 114 LSA, .504" intake .531" exhaust
You can find Comp cams from $400 - $600, depending where you buy them...
scupking
1,186
Enfield, CT
Nov 26, 2007
#10
  • Nov 26, 2007
  • #10
Is there any piston to valve issues with the 270s?
T
TGJ
1,049
#11
  • Nov 26, 2007
  • #11
People had issues with the Comp 270's because they did not install them properly but that goes for any aftermarket cam. There are cases of PTV with VT stg 1, Stg 2 cams which also resulted from improper installation. Degree the cams in and you will be fine...
bakos24
I find there is nothing better than a tasty wiener
87
134
NE, OH
Nov 26, 2007
#12
  • Nov 26, 2007
  • #12
Don't mean to jack the thread, but it may help some people out sound wise.
TGJ:
Which cam will be better sound wise. The Comp 270 or Crower Stg 2 PI SC? What I will be looking for it that nice lope sound, noticeable but not extremely aggressive. I am a complete noob with cams
T
TGJ
1,049
#13
  • Nov 26, 2007
  • #13
TGJ:
I have heard a few cars with 270's and it's idle is more lopey than my car. That said, my car because it is a 5.0L Big-Bore does make cams more mild, therefore less lopey. I would expect that my cams in a 4.6 would be just as lopey as the 270.
scupking
1,186
Enfield, CT
Nov 26, 2007
#14
  • Nov 26, 2007
  • #14
How bad will the loss in low end torque be with 270s or Crower stage 2 blower cams?
T
TGJ
1,049
#15
  • Nov 26, 2007
  • #15
You will want a 3500+ RPM Stall TC if you go with either of these cams.
blkhorse
345
Nov 26, 2007
#16
  • Nov 26, 2007
  • #16
n/a cams have more of a lope than a blower cam,because of the lsa. n/a can have lsa in the range of 108 to 112 and blower cams in the 113-115 range. thats why a blower cam with the same duration and lift will have more lowend power. Even Vt say's that their stage 3 blowers make more hp than their stage 2 N/a on a n/a motor
Winters98GT
Whoop...whoop-whoop-whoop-whoop...GANGNAM STYLE!!!
1,291
224
H Town
Nov 26, 2007
#17
  • Nov 26, 2007
  • #17
Ill second the blower cam opinion. Ive seen quite a few cars perform well at the track with the blower cams and a low gear, NA. Also, DYNO Queens dont always equate to the fastest track car. There is more to a cam than just peek HP.
Always look at the specs of a cam, not the "stage", and ask different manufacturers what they recommend. I wouldnt go with a custom grind on a stock head, stock compression motor unless there is no extra charge and you are confident with the grind. I used the old erson reground cams, the lope was nasty at an idle, but the specs turned out to be wrong. Long story short, get with somebody you trust to set and degree the cams properly if you are not doing the install.
scupking
1,186
Enfield, CT
Nov 26, 2007
#18
  • Nov 26, 2007
  • #18
I do want to get a blower someday soon (year or so). So then it would probably be best if I went with blower cams. I will talk with Tim at MPH and see what he says.
CobraRed_96_GT
1,421
UCSD/La Jolla
Nov 26, 2007
#19
  • Nov 26, 2007
  • #19
on the same note tho, N/A cams seems to perform well on FI cars like hotmustang's
Green&GoldGT
302
Virginia
Nov 26, 2007
#20
  • Nov 26, 2007
  • #20
You should look at the specs on each cam. They are both "stage 2" but Crower's have more lift ( I think .559 intake and .570 exhaust) and less duration. Comp 270s have more duration but both .550 gross lift on the intake and exhaust. More duration makes a choppier idle, but my Crowers have a unique sound. Crowers have less duration to prevent PTV contact. You can't have too much of lift and duration or it will cause PTV contact
1 of 2 Next Last
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Engine 2003 Mach 1 Automatic Upgrades assistance
  • SJK1417M1AT
  • Sep 25, 2025
SN95 4.6L Mustang Tech Dec 21, 2025
01SVTvertt
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
Exhaust April is the worst month
  • Enzio
  • Mar 4, 2026
1974 - 1978 Mustang II Talk & Tech Mar 7, 2026
LILCBRA
