  • SN95 4.6L Mustang Tech
stalls
  • Thread starter Thread starter manny
  • Start date Start date Dec 6, 2009
M
manny
590
TAMPA FL
Dec 6, 2009
  • Dec 6, 2009
hello to all and happy holiday's. the car in question is a 2000 GT automatic with 148,000 trouble free miles, i love the car. now just recently once in a blue moon when i start her up wether at home or at work she will run for about 4 seconds then die. if i put my foot on the gas pedal she will stay running. after a few miles/minutes it starts to run and idle just fine like nothings wrong. again this happens only once in a blue moon
hotrodredneck
200
Newport News Va
Dec 6, 2009
  • Dec 6, 2009
clean out the idle air control motor, maf, and throttle body with either brake cleaner or throttle body cleaner
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Dec 6, 2009
  • Dec 6, 2009
If the IAC is the type with the black vent, do not clean it. Replace it.
The IAC without the vent can be cleaned.
Perform a basic IAC test. Disconnect the electrical connection. Idle should decrease or the motor die out right. If not, there is a problem with the IAC or a vacuum leak.
Check for vacuum leaks. Small vacuum leaks have more effect at idle than at higher flow rates.
I just recently fix almost the same problem with my 2000 GT. A new Autozone replacement, no longer quits right after pulling out of the parking space.
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Z
Progress Thread zeth194 - New Guy on the Block
  • zeth194
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 26, 2026
LILCBRA
D
2.3l mustang hard starts and bogs and stalls when you floor it from idle
  • declan
  • Feb 19, 2025
  • 2.3L (N/A & Turbo) Tech
2K
2.3L (N/A & Turbo) Tech Feb 28, 2025
declan
D
