Standard or Full Length SubFrame Connectors?
SRT Handz
I tripped & fell down and cut myself & got blood
Oct 10, 2004
941
23
La Mirada, CA
I am gonna order some Maximum Motorsports Subframe connects. I need something i can weld in easy and dont have to do an ass load of fab. should i get full lengths or standard connectors?
san~man said:
And why do you say that?
Subframes make a huge difference in cutting down the flex in the chassis.
http://forums.stangnet.com/showthread.php?t=612014
you even replied in the thread.
I went driving up tantlus and couldnt tell much of a difference. people swear by them, but I dont know what's the big deal.
And wtf is with that speedbump coming down? Didnt see it, and scraped the hell out of my xpipe :mad:
BooWFO said:
Ok I'll be the lone voice standard. Also from the looks of the MM peices you better plan a few hours into getting them on there. Also most Full lengths you can't fit Cats on with them in place.
What? Where did you come up with that?
I have them and see no problem putting on a midpipe with cats. :shrug:
Reading comprehension > some of you folks
menasci said:
How would the SFC's make your exhaust scrape? Doesn't make sense.
I said and I quiote
tomustang said:
You wouldnt know but tantlus has quite a few sharp turns ;). It's where all the drifters go to act stupid on public roads, and endanger the lives of other people.
Ok the MM's shouldn't be a problem seeing how they mount UNDER the front Frame section BUT lots of the others onthe market run alongside the frame and I seriously doubt those will clear a Cat, I know for a FACT I couldn't finish welding mine in till they were removed. Also seeing as how they sit lower than the frame how bad is scrapping on them then?
Looks like you have plenty room for cats.
Do you have a panhard rod or spherical bearing control arms? if you don't have something to locate the rear axel better you won't notice the subframes as much.
there are multiple problem areas on a mustang. rear axel location is the most overlooked problem IMO. could not belive the differenc the MM drag arms made on my car. In hindsight I would have bought the parhard rod as well.
