  • SN95 4.6L Mustang Tech
stang stuck in reverse
  • Thread starter Thread starter BadMoFo
  • Start date Start date Jun 24, 2004
BadMoFo
I will sleep with a Mod for a CT
2,911
New Bern NC
Jun 24, 2004
  • Jun 24, 2004
ok I got to work this morning and put my 99 cobra in reverse and now it wont come out. I can press the clutch all the way to the floor and it engages but the stick will just not move out of reverse. does anyone have a clue to what might be wrong and how much it might cost to fix?
btolenti
277
Gilroy, CA
Jun 24, 2004
  • Jun 24, 2004
have you tried the clutch adjustment? Pull up on the clutch pedal with your foot until you hear it 'click'....
brandon_lawson7
239
Morehead, KY
Jun 24, 2004
  • Jun 24, 2004
The same thing happened to me last summer. It could be the clutch cable but Im not too sure though because thats what I thought was with mine. But it wasn't it was my whole tranny! But hopefully that wont be your problem. Try going in reverse and then try throwing it into first. Once you get to where it wont go any farther go back into reverse and then tap the clutch and then try to go into first. I tried that the first time my reverse got stuck and it worked. I just hope your tranny isnt out which it shouldnt be.
68 & 00 GT
2,407
HOUSTON TEXAS
Jun 24, 2004
  • Jun 24, 2004
could you get it out of reverse w/o the engine running ?
BadMoFo
2,911
New Bern NC
Jun 24, 2004
  • Jun 24, 2004
thats just the problem the shifter will not move at all. and no I couldnt get it out of reverse with the car on or off.
TacBear
1,243
Jasper, AL
Jun 24, 2004
  • Jun 24, 2004
TSB 01-23-5
2--N800419-S301 NUT M10X1.5 HE
1--F8ZZ-7230-DE FORK ASSY - TRANS
1--F0TZ - 7025-B BRG ASY - TRANS
6--F6ZZ-7030-A RG-TRANS OUTPUT
3--F6ZZ-7M133-A RING TRANS REV
3--XT-5-QM MERCON R V AUTO
R&I exhaust, cut exhaust retaining nut off, R&I trans set up on bench fixture, dissasembled trans to remove reverse and 5th shift fork, R&R shift fork rear bearing and snap ring, reassembled trans and reinstalled.
D
DerekStangGT
My package is in the mail!
Feb 18, 2003
1,068
Jun 24, 2004
  • Jun 24, 2004
same exact thing happened to me, had to get it towed away it was the reverse synchronizer. good thing it was warrenty work!!
BadMoFo
2,911
New Bern NC
Jun 27, 2004
  • Jun 27, 2004
do you think ford will throw a fit because of the long tubes? cause I know in order to get the trans out now they are going to have to remove one of the headers.
H
huesmann
332
  • Jun 27, 2004
Tranny trouble is unrelated to exhaust, unless for some reason you've got gobs of HP coming out as a result of the exhaust. It's their problem if they gotta R&R something to get something else out under warranty.
BadMoFo
2,911
New Bern NC
Jun 27, 2004
#10
  • Jun 27, 2004
  • #10
I know its not related but I figured that they would throw a fit cause they have to do more work than normal to remove the trans. you know how ford places are, they do everything they can to dodge doing the work without charging you.
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
P
Is it normal for all of this to go wrong or did I get played when I bought this ONLY A MONTH AGO.
  • ponygal02
  • Nov 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2025
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
F
Rear Drum Brakes
  • Fri Guy
  • Jan 3, 2025
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 8, 2025
Scrapla347
