  • 1994 - 1995 Specific Tech
started taking off my heads....
  • Thread starter Thread starter MI95Cobra
  • Start date Start date May 4, 2007
MI95Cobra
451
Oklahoma City
May 4, 2007
  • May 4, 2007
well, i'm ready to pull my cam, when my heads came in today....so i started pulling my old heads....when i started to pull the #3 bolt in sequence i had radiator fluid pour out....right into my exhaust......i'm like wtf???? i figure its a good thing that i decided to install the cam now, because it was just a matter of time before i blew a head gasket or worse....
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
May 4, 2007
  • May 4, 2007
That's not uncommon....the lower head bolts thread directly into the water jacket. This is why you use sealer on the threads of the lower bolts when you re-install the head.
MI95Cobra
451
Oklahoma City
May 5, 2007
  • May 5, 2007
ohhh....interesting......
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
May 5, 2007
  • May 5, 2007
Did you drain the coolant when completely before you started????
T
tjh566
608
Northern Va
May 5, 2007
  • May 5, 2007
same thing happend to me, right into my h-pipe, it'll burn off once you start it, so the LITTLE smoke show you see when u fire it up dont be worried.
MI95Cobra
451
Oklahoma City
May 5, 2007
  • May 5, 2007
i thought i emptied it........
T
tjh566
608
Northern Va
May 5, 2007
  • May 5, 2007
there will always be some left in the motor from my experiences.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
May 5, 2007
  • May 5, 2007
OK Jimmy
Here is how you can never have that happen to you again
See those two drain plugs on each side of the block.
Put a petcock with a screw like you see in the bottom of radiators
in the lowest of the holes on each side.
Next time you wanna pull your heads you just turn the valve to drain
with no mess all over the place
Grady
MI95Cobra
451
Oklahoma City
May 5, 2007
  • May 5, 2007
ok...thanks grady....
MI95Cobra
451
Oklahoma City
May 5, 2007
#10
  • May 5, 2007
  • #10
well i started putting the beast back together again....fun, fun...especially with 3 kids around.... anyway i changed my heads, put in my cam, put back on my headers, spark plugs, timing chain, the timing chain cover, the a/c coil, new lifters, new pushrods, and the spider thing that holds down the lifters....tomorrows my little girl is turning 5...so i'm taking the kids to go see spiderman 3 and then to a party at my grandparents house....so it'll probably be another 4 days before i continue....:SNSign:
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
J
can you use the heads off a H O 302 to put on a regular 302 engine
  • Jan H
  • Feb 25, 2026
  • Other Auto Tech
Other Auto Tech May 17, 2026
nickyb
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
