Starting issues with 89 LX5.0
CManT1914
3,172
Killeen, Texas
A friend of mine has an 89 LX 5.0 that's currently having some starting issues. The headlights and all accessories will turn on, but when he goes to crank it, nothing happens. No noises or anything. I'm guessing this may be starter related, but he said the solenoid was just replaced last fall. Anything we can check to see if the starter on it is bad?
Here's a checklist:
Since some of the tests will bypass the safety interlocks, make sure that the car is in neutral and the parking brake is set. Becoming a pancake isn’t part of the repair process…
Check battery, terminal connections, ground, starter relay switch (also known as solenoid) and starter in that order.
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection: more than .5 volts across a connection indicates a problem. Do the measurements while you are trying to crank the engine.
See http://www.fluke.com/application_notes/automotive/circuit.asp?AGID=1&SID=103 for help
1.) Will the car start if it is jumped? Then clean battery terminals and check battery.
2.) Check the battery to engine block ground, and the ground behind the engine to the firewall.
3.) Then pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Then jump between the screw and the terminal that is connected to the battery. If it starts, the relay is good and your problem is in the rest of the circuit.
4.) Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then the relay is bad. See http://www.autozone.com/images/cds/gif/large/0900823d80195963.gif for 88-90 year cars .OR see http://www.autozone.com/images/cds/gif/large/0900823d80195964.gif for 91-93 year cars. See http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-95 model cars.
5.) Jump the big terminals on the starter relay next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
6.) The starter may be hung, loosen up the bolts that hold it on, and give it a good whack with a big hammer. Tighten up the bolts and try again.
7.) If that doesn't work, use a jumper cable from the positive lead on the battery direct to the starter post where the big wire from the relay connects. If it cranks then, it is the power wire from the relay gone bad. This will be hard to do, since there isn't much room to do it.
8.) Pull the starter and take it to Autozone or Pep Boys and have them test it. Starter fails test, then replace it. If you got this far, the starter is probably bad.
:hail2: Are you sure you didn't design mustangs? lol, you're a mustang god. Thanks, I'll try and get with him sometime this week or weekend to work on it. I'm hard pressed for time as I'm still working out the bugs on mine though.
Yep, JR is the man!
I would pay particular attention to number 4 on his list. The switch has a sliding adjuster (like some brake switches do) and if out of adjustment (like he jambed the pedal through the floor at some point) the signal from the ignition switch to the solenoid trigger wont make it.
Good luck Chris. I hope you got your meter finally. :nice:
