starting my swap
  • Thread starter Thread starter dave181760
  • Start date Start date Mar 29, 2010
  • 3
  • 4
  • 5
  • 10
First Prev 3 of 10 Next Last
dave181760
233
palm springs ca
Apr 10, 2010
#41
  • Apr 10, 2010
  • #41
hey does anyone have a pic of the remoovele of the e brake cable i want to drop my rear end and dont know how to do ive never removed the drum nor do i know how to do it thanks guys
willrich51
11
michigan
Apr 10, 2010
#42
  • Apr 10, 2010
  • #42
E brake
If your not using those brakes, pull of the drums and unbolt the four bolts holding on the backing plate, give a hit with a hammer and let it hang.
Cobra912
1,777
11
39
Wish I was anywhere but here
Apr 10, 2010
#43
  • Apr 10, 2010
  • #43
dave181760
233
palm springs ca
Apr 12, 2010
#44
  • Apr 12, 2010
  • #44
i dont wanna damage anything thow with the hammer cause im leaving it 4lug for now
is there another way to do it without messing anything up thanks
dave181760
233
palm springs ca
Apr 12, 2010
#45
  • Apr 12, 2010
  • #45
here is a random pic for now, i gota get more.
willrich51
11
michigan
Apr 12, 2010
#46
  • Apr 12, 2010
  • #46
e brake
Give the backing plate a little tap, you don't have to hurt it. If the rear brakes are in good shape on the car you're fixing, do it on both cars. The brake and e brake cable will stay on the backing plates so you don't have to mess with them on eather car.
Good luck
dave181760
233
palm springs ca
Apr 13, 2010
#47
  • Apr 13, 2010
  • #47
Good luck
hey i need to swap my fuel lines where do i start and how do i do it.
and heres a stupid newb ? i needa drain the trany flued how do i do it.
lancec2c30
570
Washington
Apr 13, 2010
#48
  • Apr 13, 2010
  • #48
Go to an auto parts store and buy "fuel line disconnect tools" They should come in a pack of 4. they look like little plastic donuts.
You have to use those to separate the compression fittings on the fuel lines at the engine. Then You un-hook the rubber hose at the fuel filter (gas tank end). After that just remove all the body screws or rivets that hold the fuel line to the chassis and pull it from under the car.
For the transmission fluid, passenger side of the tranny, there should be 2 plugs. They have a square drive insert. Put the head of your 3/8in ratchet in the UPPER plug first. It would be pointless to remove the drain plug, just to find out the upper fill plug won't come out. And you can't put any fluid back in your transmission.
dave181760
233
palm springs ca
Apr 13, 2010
#49
  • Apr 13, 2010
  • #49
thank you im bout to pick up the tool and drain it lol also do i need to empty what gas i got in the notch its not much but the donor car has like half a tank in it
lancec2c30
570
Washington
Apr 13, 2010
#50
  • Apr 13, 2010
  • #50
It doesn't matter how much fuel is in the tank. The only gas that will spill is going to be what is left in the fuel lines.
UMDSmith
226
Salisbury, Maryland
Apr 14, 2010
#51
  • Apr 14, 2010
  • #51
I know you already got them loose, but for future reference....
Another trick to break a stubborn bolt loose, if the position allows, is to use the weight of the car against of the bolt. I've done this when I had to help a guy get a flat tire off some junky rusted old minivan.
Take your junk ratchet, an extension pipe and get the pipe end to be low to the ground. Put a floor jack under the end and start cranking away. Eventually it will either bend the bar, or break the bolt loose. Plus it is a bit safer than jumping on the end of a pipe, especially for those with bad knees.
Work smarter, not harder.
dave181760
233
palm springs ca
Apr 14, 2010
#52
  • Apr 14, 2010
  • #52
thanks i wasnt sure about it beter safe then sorry lol.
i got another ? for you how do i disconect the throtle cable my budy di it on the 4banger i would ask him but he moved to L.A and also can i use the one from the notch or do i swap the whole line as well.
dave181760
233
palm springs ca
Apr 14, 2010
#53
  • Apr 14, 2010
  • #53
i never thought of that thanks for the tip.
lancec2c30
570
Washington
Apr 14, 2010
#54
  • Apr 14, 2010
  • #54
On the throttle cable you have to undo the retaining clip on the throttle body. Once that is un-done, the end of the cable pops off of a ball on the throttle blade. Just pry it off with a screwdriver.
dave181760
233
palm springs ca
Apr 15, 2010
#55
  • Apr 15, 2010
  • #55
thanks i went out and did what you said and got it off. i got everything prety much disconected on the motor and ready to pull it out i just dont know where to hook the chains for the hoist to pull that bad boy out its geting on my nerves do you have pics on how you had yours when you pulled it if so could you post them or pm me with them thanks again for your help
dave181760
233
palm springs ca
Apr 16, 2010
#56
  • Apr 16, 2010
  • #56
anyone able to give any sugestions on where to hook ma chains up to pull this motor out
lancec2c30
570
Washington
Apr 16, 2010
#57
  • Apr 16, 2010
  • #57
On the V8?
There should be hoisting points on the drivers front and passenger back of the engine. They should be bolted to the block behind the header.
dave181760
233
palm springs ca
Apr 16, 2010
#58
  • Apr 16, 2010
  • #58
lancec2c30 said:
On the V8?
they were these brakes that were bolted up witht he stock header but are long gone now cause i got bbk headers on there so they were removed i went on youtube abd some people had them on the heads pass rear and driver front is this what you are talking about
lancec2c30
570
Washington
Apr 16, 2010
#59
  • Apr 16, 2010
  • #59
If you removed them when you went with aftermarket headers, then you're right. That won't work.
It's kind of risky, and I wouldn't want you to break a bolt off in the block. But some people will pull a bolt out of the header front drivers side and pass. rear. Then install a longer one. You put the longer bolt through one of the chain links then into the header and block. Pull then engine out from the middle of the chain, to keep everything somewhat balanced on the way out.
dave181760
233
palm springs ca
Apr 18, 2010
#60
  • Apr 18, 2010
  • #60
damn headers wont let me put a longer bolt in so im going to have to it the other way this things pissin me off but ive been doing little things here and there so im hoping by the end of the week ill have it swaped over
  • 3
  • 4
  • 5
  • 10
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
L
Engine Why won't the motor start if I have spark and fuel
  • LeviAnderson
  • Nov 20, 2025
Fox 5.0 Mustang Tech Nov 20, 2025
AeroCoupe
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
