I used the plastic ones just yesterday on my 94 parts car. You spread the plastic ring apart and slip it over the pressure fitting on the fuel line. The pressure fittings are located on the passenger side down by the splash guard. Once the tool is on the connection, just jam the sleeve of it into the fuel rail side of the line.
You'll feel it pop into place, next step would just be to yank the lines apart.
thanks bro. your notch looks clean with the black rims i like the look
what are these conectors, i know harnesses are not all the same, things are diff from the 89 donor car, so im learning as i go along, any help would be appreciated.![]()
Thanks.
I'd have to go look at my car to double check, but my 87 donor didn't have those, and my 92 did.
I think they have relay's plugged into them. Then they just mount to the side of the strut tower with those push lock plastic tabs.
Yep those are relays. Your gonna run into trouble with that harness. Your 91 has the fuel pump relay under the driver seat. One of those relays in the pic is the fuel pump relay for the 93. Stop now and sell the harness. You need to find a harness from a 91. They are stand alone harnesses. I'm doin the swap right now on my 93 and at first I thought I could use the v8 harness from the 91 parts car. Turns out you can't w/o modifying the harness. I found a 93 harness on eBay and unforunately a few weeks back I sold my 91 harness or I woulda sold it to you.
I hope it was from a 91. And on a side note, I hate how eBay sellers have "fits 87-93." Bitch no it doesn't. Lol.
You should be good if the description said 91. And I always buy my stuff from 50resto.com. I have headliner in a box waiting to be installed that I bought from them.
