starting trouble still
j1586
10
I have a 94 gt and it recently began having trouble starting. it acts like the batery is dead when it has a full charge and even with new batteries. I have checked the fuse box for grounds and even replaced the starter, coil, and starter cable. no mods or excessive sound systems. I even tightend the ground wires as a check. somone said something about a cam sensor in another post. what is its job and is that a possiblity? any help out there?
possibly a starter problem?? i know i was having problems starting my car and it turned out the bottom bolt of the starter was creepin out making a piss poor connection to the flywheel. just a thought. there are also two wires to the starter too. they do start to go bad sometimes
Did your starter just keep cranking? Once in a while my starter goes retarded and take a lil while longer.
First test. Take the car down to autozone and have them test the alternator/battery. I know you replaced them, but you never know if the "new parts" are really new. Even from autozone. I have friends that work at autozone and they have some strange stories to tell!
If the battery/Alt test fine, here is step #2:
Have someone hook up jumper cables to your car and see what happens. If it starts fine, you have bad cables. You need to look at your cabling. Clean every single contact (battery connections, motor ground, starter contacts, secondary ground if there is one). If that doesn't work, replace the main ground cable. Then replace the main positive wire if that doesn't work.
Give me some more information on the car. Can you do a clutch start and the car will run fine (assuming you have a standard)? Can you turn all the lights on, press the brake pedal, and the voltmeter doesn't drain much?
If you are only having starting problems, then I assume it is one of the cables connecting to the starter. You replaced the main hot wire to the starter, so you need to check/replace the ground and ignition wire. Hook up a voltmeter to the positive and negaitve terminals of the starter. You should ALWAYS see 12V. Now hook up the voltmeter to the ignition wire and ground wire. You should see 12V only when someone turns the key to start the car.
If you don't see 12v on the accessory wire and ground, you need to look into the accesory wire. Since you see 12V with the positive and negaitive wires, they must both work. So now all that is left is your ignition wire.
My dad's maxima would not start. His starter/batt/alternator were fine. All cables were clean, no problems. But his ignition switch went haywire, so it wasn't sending the 12V to the starter and letting it start.
Check the connections to your ignition wire. See if you have continuity along the wire. If the wire has continuity, then I would check the ignition switch (connects to the back of the key cylinder). When you turn the key, a plastic tab turns the ignition switch to the proper spot. Run a wire from the positive terminal of the battery to the starter wire on the ignition. If the starter cranks, the ignition switch is bad. 20 bucks, and you are ready to go!
Scott
yeah...it just kept spinning and spinning. it used to take a few seconds longer than normal and then one day it just kept spinning. looked under and whoa...lost a bolt :lol:
