H hardflip New Member Aug 7, 2004 17 0 0 Washington Aug 8, 2004 #1 Aug 8, 2004 #1 Ok when taking apart your engine how do you prevent things from rusting and what do you do if things start to rust like the parts on the head or even the cylinder walls?
TT91 Active Member May 23, 2003 1,536 0 36 Paramus, NJ Aug 8, 2004 #2 Aug 8, 2004 #2 Coat everything in oil or WD-40, wrap them in plastic bags in a dry area, keep away from natures elemtents.
H hardflip New Member Aug 7, 2004 17 0 0 Washington Aug 8, 2004 #3 Aug 8, 2004 #3 is there anything you can do if rust gets on it? Or is it just over?
T TheUser Active Member Jul 25, 2003 1,859 1 36 Springfield, MO Aug 8, 2004 #4 Aug 8, 2004 #4 you can get the rust off w/ steel wool or lightly sanding w/ sandpaper
