I instaled a Steeda Clutch Quadrant and had q question. My lutch doesn't grab till it is almost all the way off the floor, like maybe an inch before the pedal would just be in normal position. Is this normal. Is that the correct release?
I would not drive it. If your clutch is not releasing until it is all the way at the top then it has too much tension on it. (Kind of like riding the clutch). It is like you are pushing the clutch in half way all the time.GATOR98GT said:Is It going to hurt if I drive it?
Is that what you are running? A Steeda quick release? Or a double hook?GATOR98GT said:Ok, maybe I shouldn't be runing a oem cable with the steeda clutch quadrant? Is the quick release quadrant supposed to make the lutch grab hi?
Then it needs to be hooked like the one in the picture to give you the proper length. On the top setting. Is yours like this?GATOR98GT said:It is a double hook
It should. It will give your cable more length which should make your pedal grab closer to the floor.GATOR98GT said:I believe it is hooked on the innermost one, I will have to check it out tommorow morning to make sure. So if I just adjust it then my problems should be solved? I take it, it would not be safe to drive tonight about 20 miles?
