step by step on how to put rear end back together
  • Thread starter Thread starter tiptopss
  • Start date Start date Jun 11, 2009
T
tiptopss
48
  • Jun 11, 2009
cant seem to figure this out. I dont know the steps on what to put together first. Do i slide the trac-loc in the rearend with the trac-loc a complete assembly? I need to slide the c-clips in there, but everything is in the road, I need help, thanks.
Aryan15
236
CA
Jun 12, 2009
  • Jun 12, 2009
Yes, the whole assembly should be together before you install it. Make sure the spider gears are lined up for the pinion pin before you install it. The c-clips go in after the axles are slid in.
Duncan McDougal
99
Gainesville, FL
Jun 12, 2009
  • Jun 12, 2009
How to rebuild a Ford 8.8
67coupe
658
402
93
Huntsville, AL
Jun 12, 2009
  • Jun 12, 2009
The instructions below assume you have measured the backlash and gear pattern and are ready to do final assembly.
1) Install the assembled diff (minus the pinion shaft bolt...the large pin) into the rear end housing.
2) Install bearing main caps (same side as removed from) and torque to 85 lb-ft.
3) Slide one axle into housing (careful not to cut seals) and into splined spider gears in diff. Push axle all the way in, and install c-clip.
4) Repeat for other axle.
5) Install pinion shaft bolt. Install pinion shaft retaining bolt and torque to (15-30 lb-ft). Use a new bolt with fresh thread locker. It's common for these to break, so use a new one and be careful!
6) Install rear cover.
Here is a pretty good "how to" page.
Back to the Homepage
67coupe
658
402
93
Huntsville, AL
Jun 12, 2009
  • Jun 12, 2009
Another good source.
So you want to install your own gears: A 'how to' 8.8 gear install - Ford Explorer Ranger Enthusiasts Serious Explorations
T
tiptopss
48
  • Jun 12, 2009
u guys r the best, going back now and try to get er back together, will give an update later on.
T
tiptopss
48
  • Jun 14, 2009
hey, thanks agian, I got it all installed, was pretty easy once you figure out the right way to do it, but i took it for a spin and driving along is good, but if i shove on it, I get a loud screeching/grinding sound coming out of the rear end, I am hoping it goes away, but i think she may have tl come back apart, any ideas?
L
Lawbreaker5.0
543
Texas
Jun 14, 2009
  • Jun 14, 2009
what where you doing to the car in the first place? adding gears?, rebuilding traction lok?, we kinda need to know these things, not just How to put the rear end back together
T
tiptopss
48
  • Jun 15, 2009
hey, I rebuilt my trac-loc, I put in new clutches and steels
P
Rear disk brake caliper parking brake adjustment
  • parrotguy
  • Oct 23, 2025
1974 - 1978 Mustang II Talk & Tech Oct 24, 2025
2Blue2
  • Mindseye007
  • Aug 16, 2026
Mindseye007
O
Help
  • OnisimusD
  • Oct 13, 2025
1965 - 1973 Classic Mustangs -General/Talk- Oct 14, 2025
OnisimusD
O
Engine Information that is Needed When You Post a "Car is not Running" or "Car is Running Poorly" Thread
  • AeroCoupe
  • Apr 28, 2025
Fox 5.0 Mustang Tech May 4, 2025
Bullitt347
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
