I made a thread about two weeks ago about a problem I suddenly developed. The car has run great for 700 miles and then it developed a nosing over issue (it feels and runs like the spark just quits under load and the car noses over as if it were a carb'd car that flooded out while still cold). It ran great one day and the next I had this issue. All I did was to go into my EEC Tuner and lower the fan temps and lower the global spark added a degree due to high temps we've been having here. The only thing I did differently this time from all others was to tune from the driver's seat versus the passenger seat. I fell I may have pulled on the serial cable a little since it was stretched to make it that far. I went for a ride the next day and it started this nosing over problem. I then replaced all the spark plugs and gave the car a once over to make sure none of the plug wires had come off, were loose, were burnt, etc. the dizzy is still tight and in the same spot it has been since I started the car this year, the TFI is plugged in, the MAF is plugged in, I put the eec settings back like they were before I messed with them, etc. I took the car for a ride and it still had the same problem.
I then pulled the codes, cleared them and then disconnected the battery. I also removed the computer from the car, took off the back plate and removed and reinstalled the serial cable into the eec tuner. The tuner itself was firmly seated into the computer, but I did not remove it. I put it all back together and went for a ride. I made it about 5 miles with no issues so I thought I had fixed the problem.
I went to take the car for a ride on Saturday and before I even made it out of my driveway it started acting funny and didn't want to idle. I kept giving it running via the throttle and attempted to pull out onto my street. I didn't make it but 15 feet and it shut off and didn't want to run. I did manage to get it started but it was all I could do to keep it running. It exhibited the same symptoms again. I made it into the garage and it shut off.
I went down last night to pull the codes and I am unable to. I connect my code scanner and then cycle the key forward. When I do the fan kicks on and doesn't shut off, and the scanner won't pull any codes, it acts like its not connected to anything.
Is my computer dead??? Or is my eec tuner shot? I'm going to attempt to totally remove the eec tuner today, check for codes again, and if that works I will attempt to drive the car with no eec tuner. I'm really thinking its an eec issue since all I changed was eec settings and I'm now having issues with the fan not shutting off with the key in the on position, and the code scanner can't seem to connect to the computer now.
Can a computer be checked by a garage to see if its bad or not? Does anyone else have any other ideas? Is eec tuner still in business?
your old combo used 24's and a meter caled for them
J/K.
