It's not like this is the first time for me.
BUT. I changed the gasket a couple of months ago, and last week, there started showing a small puddle of coolant on the water pump. SO, I decided to change it before the summer heat.
I changed the gasket yesterday, cleaned the intake port and water neck port really well, sucked the coolant out of that area, put a little RTV on the water neck side and pressed the gasket into it. THEN, put a layer of RTV on the intake side of the gasket, bolted it up, and waited about 3 hours to put any coolant back in.
I filled it up, put in a bottle of W/W ($7), got all the bubbles out, kept checkng the water pump...FINE.
I took it for a 5 minute test drive, and when I pulled up, COOLANT ON THE WATER PUMP
dripping from under the neck where I just sealed it.
I dont know If I should let the RTV dry, THEN put the neck on, or put the neck on right away, then let it "dry into the crevaces" around the neck or what.
Im pretty sure I did everything right.. Should I DOUBLE THE GASKETS between the water neck and the intake or what??
ANY ANSWERS?
RC
ANY ANSWERS?
RC
