also, what do you guys think of the stock 8 inch?
Drastic weight reduction and BF Goodrich T/A's (low traction) likely help too.
ok hey thanks for the info, my gears now are currently going out, there is alot of backlash, especually at cruising speed
Oh! also wanted to add that you might just want to just re-set the backlash.
I've been finding quite a few 9" rears on 1/2 ton trucks with pinion yokes walking right off! (excessive rear u-joint wear, vibrations, etc..) Just check the torque on that nut and see if it takes anymore turns. If it's loose you might be able to re-torque with the current crush sleeve and possibly cure the backlash. The 9", i believe, is 100ft lbs, the 8" has to be pretty close if not the same as that.
SSM went tits-up years ago. Someone's buddy on the forum makes them though.
This dude:
http://www.stumpysfabworks.zoomshare.com/2.html
He makes SSM style lift bars and pretty cool lookin' Mustang II frame connectors. (wish I had a time machine). Someone sold me Comp Pinto frame connectors and said they would fit. They did, but it took a spool of mig wire and a plazma cutter LOL![]()
stumpys sub conn are just like a set of custom made conn.
they fit very tight to the floor. bolt to the rear spring perch and fit over the top of the front rail giving you more area to weld up. i removed my ssm conn and will be installing stumpys in a few weeks. he sells them as weld in or bolt in and the hardware is included.
what is different from the ssm conn`s vs. the stumpy made ones?
