stock brake upgrade
  • Thread starter Thread starter skinnypGT
  • Start date Start date Feb 5, 2008
skinnypGT
211
Radcliff, KY
Feb 5, 2008
  • Feb 5, 2008
I was looking at installing a stock brake upgrade kit on my car and was wondering
if the kits are worth the time and money.
my rear drums are in need of replacing. my car is only used for street driving and I do not anticipate ever using it for any serious drag racing
Has anyone tried these kits and would you recommend them ?
302RollinHard
Columbus, OH
Feb 6, 2008
  • Feb 6, 2008
Are you talking about the Maximum Motorsports stock brake upgrade kit? If so, the braided lines will give you a better pedal feel, and the steel caliper bushings will help keep your pads square under braking.
In my mind, the stock brake setup is fine for street driven cars. I can lock up the brakes at will which in my mind means that the tires are the limiting factor for stopping distance.
At any rate, I have never ever heard from anyone that the stuff that MM sells is junk.
I like my kit. Brakes feel alot more competent.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 6, 2008
  • Feb 6, 2008
See http://www.svo73mm.cjb.net/ for the best and cheapest brake upgrades. The site doesn't sell anything but some fittings, but the tech notes are great. It tells you what junkyard or remanufactured parts to use to upgrade your brakes. It has almost everything you could want to know about Mustang brakes on it.
Mustang5L5
Mod Dude
Feb 18, 2001
43,337
18,064
224
Massachusetts
Feb 6, 2008
  • Feb 6, 2008
302RollinHard said:
In my mind, the stock brake setup is fine for street driven cars. I can lock up the brakes at will which in my mind means that the tires are the limiting factor for stopping distance. .
My opinion. Stock fox brakes are dangerous by today's standards. They are too small for a 3400 pound car.
Locking the brakes only means the tires are not grabbing well. Put a decent set of rubber on and attempt a 80MPH panic stop in a fox with stock brakes and you will see them fade to hell near the end. I crapped my pants many times in that exact situation.
If you are just commuting around, more than likely they would be fine, but since it a Mustang and most people like to mess around here and there, you might find yourself in a situation where you need to stop fast.
I upgraded my Fox to SN95 13" brakes and it was the best mod i ever did. It made the car more fun to drive because i could dive into a highway offramp faster and bleed the speed off near the end easily.
Now, would stock brake upgrades help? Sure. But don't expect too much. The front spindle/hub design is prone to building up heat quickly and fading away.
aaros
114
Feb 6, 2008
  • Feb 6, 2008
+2 on the maximum motorsports upgrade, more firm pedal. if your not wanting to do a sn95 swap then drop the cash on this.
Turkey Sammich
I can't fap normal. I cracked a rib, then my ankle
Jul 12, 2006
154
Feb 6, 2008
  • Feb 6, 2008
The Maximum Motorsports Brake Upgrade Package was installed on my car last April. I also bought Power Slot Rotors. I noticed a HUGE difference in my braking ablity. It wont be as good as good as a 5 lug brake package, however, it's far better than stock.
W
New here, 1967 getting an efi 348 stroker.
  • Weeman348
  • Mar 27, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 27, 2026
Weeman348
W
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
