stock intake tube mounting problemm
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
my problem is that one of the 2 bolts that hold the airbox to the fender on my car came loose from the fender. Hard to explain but hopefully someone will know the bolts I am talking about. They seem like they are glued to the fender somehow to hold the box that the filter cover that clamps to it....anyone ever run into this problem? what did you do and how did you fix it...any ideas are welcome
theese ones
the one his finger is on
no mine looks like it was maby glued there or maby they were spot welded from factory...I don't know I will try and weld it on...I haven't realy looked into it but it's one of the little things that bug me about the car. I will maby take a pic and show how it came apart
Those aren't bolts. Those are rubber isolator stud mounts (or whatever the heck they're called.) One end threads into the captured nut in the fender apron. The other end protrudes out so you can mount the air box onto and then fasten down with nuts.
LRS calls them rubber air box mounts p/n LRS-9686K
