Stock Springs and Cams?
bnmc98
62
Bozeman MT
Recently got a set of CMS stage 1 cams for a killer deal and wanted to get a poll of people using stock valve springs for stage 1 cams. I have read enough to realize that most people seem paranoid of using the stock springs and go aftermarket. Is it the lift, or the RPM that is the concern?
I know the CMS site says OK with stock springs, so my question is why wouldn't I use them? I don't have an estra $300 laying around for spings and the tool so I would just have to keep the stock PI cams if I didn't use the stage 1s. It is a stock PI motor they will go into.
I would like to hear from people using the stock springs with their cams.
How many miles on them?
what cams?
any problems?
Thanks
CMS stage 1 cams , no issues so far.... 20k Kilometers , i think they are abit too soft to hurt anything , once you get them tuned and throw some long tubes , you cant even hear them idle but you would pick up some nice oomph , hope this helps.
The stock springs are fine for a stage 1 cam; some stage 2 cams are even okay with stock springs. Its when you start getting into the higher RPM levels that you want to consider changing your springs. The reason you want stiffer springs for higher RPM applications is to prevent valve float. Valve float is when the engine, or cams to be more accurate is spinning so fast that the valve doesn't even have time to close before the lobe comes around to open it up again. This is bad. Very bad. Unless your getting your car tuned and moving the stock rev limiter up, I wouldn't worry about it, HOWEVER, if you have the cash to do it, save yourself time, and worry and just replace them now. Its cheap insurance. You also have to be careful when selecting your springs, too stiff of a spring and you lookin at buying the seats too, too high seat pressure can cause problems as well.
