I just ordered some Strange 10 way adjustable struts for my fox. Original 4cyl car and still has the 4cyl spindles. The mounting ear on the spindle is thicker than the v8 spindles and the struts will not fit on the mounting points at the spindle. Can I grind the mounting points down to fit the struts or should I swap to v8 spindles, brakes, etc..? If you can grind them down, do you take same amount off of both sides or just one side?? I think I read they are 1/4" thicker.
(shipping will vary but can do that fairly cheap)
