Street Heat Installation Instructions
dsg02
146
Does anyone have a copy of the Trick Flow Street Heat intake manifold installation instructions they could email or fax? I bought it used and don't have them (and don't see anything on the website). There are plenty on Edlebrock instructions out there and I'm sure they're not that different, but I'm sure it wouldn't hurt to have them. Thanks.
don't have them I think I threw them out after about a month. Didn't even need them to install the intake. Just follow the lower manifold torque sequence listed for the stocker in a haynes or chilton manual. Also you must use jb weld or some other strong epoxy to hold the oil plug that is in the block just below the lower intake once you take the lower off you will see it in the back of the lifter valley where the lower manifold gasket sits at the rear of the lower intake. Just put the jb weld all over the top of the plug so it won't come out. Also there are a lot of plugs that you must use in the lower intake to block off some of the holes used by the 87-93 cars that ours don't need. Trickflow supplies these plugs wen you buy the intake. I'll help you If you have any problems let me know
