  • 1994 - 1995 Specific Tech
Stuck injector
  • Thread starter Thread starter canadian94gt
  • Start date Start date May 5, 2005
canadian94gt
139
Debert, Nova Scotia,Canada
May 5, 2005
  • May 5, 2005
The last time I took tyhe car out last november I hit a large water hole. I thought maybe I sucked some water in the fenderwell intake and maybe bent a rod or a valve as the number 5 cylinder is dead. A buddy came over today and we checked for spark and there is lots of spark. We decided to do a compression test and wow. It went way up over 250 on the #5 went to #6 andas I whirled it over the fuel literally was squirting right out the plug hole of # 5. Checked # 6,7,8 and they were 150, 149, and 150.
So my question is is my injector stuck wide open or is it another problem and what would cause this? they are 24 lb injectors. I have a set of thirtys and a new mass air meter but I would still like to know if it is the injector itself or a computer or wiring problem. It seems funny that it happened rightafter I hit the waterhole.
thanks in advance
bimmertech
1,123
merriam, ks
May 5, 2005
  • May 5, 2005
if you have a node light plug it in and see if it lights up with the koeo. if you don't have a node light measure voltage across inj connector with koeo. if voltage is present you have a short to ground somewhere
HISSIN50
34
129
May 5, 2005
  • May 5, 2005
to add, i believe that the puter sends ground to excite the injectors (they have constant 12 volts with the key on). so look for constant ground. (i know this is true on foxes, but dont know for certain on SN's).
have you run a cylinder balance test?
good luck.
canadian94gt
139
May 15, 2005
  • May 15, 2005
Well, it turns out it was an injector. Move it to another cylinder and it did the same thing. Swapped them for the 30lb and switched meters and it runs great accept for a little rich. Time to get the laptop out again i guess. Thanks for the replys
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Oct 25, 2026
roldy
R
H
Misfire cyl 2 under 3200 RPM, not the coil or injector
  • Hydranmenace
  • Nov 14, 2025
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Nov 14, 2025
Hydranmenace
H
C
Engine Cylinder 5,,7, & 8 run significantly cooler than the other cylinders
  • Crisfixes
  • Sep 27, 2025
Fox 5.0 Mustang Tech Sep 27, 2025
Fuel 1990 mustang gt 5.0 no ground signal to fire injectors
  • brandyn200
  • Sep 5, 2025
Fox 5.0 Mustang Tech Sep 6, 2025
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
