Studdering under load/acceleration (not fuel filter)
kirkyg
3,568
Beaumont, TX
I recently noticed my car studdering under acceleration especially when putting it in higher gears (4th, 5th) and pressing the pedal down a good bit at lower rpms. After reading around about this I came to the conclusion it was most likely just a clogged fuel filter so I changed that this weekend. I took it out for a spin and still at lower rpm's and it studders under load.
What's the next step to diagnosing? Any ideas on what else might be wrong. Honestly, I have a baby on the way and want to get the car tuned up and sell it so I need to get the little things resolved quickly.
I don't see any check engine lights and no other signs of problems. Could it be a bad coil pack? Thanks for any help in advance.
Kirk
Kirk
Pull each COP one at a time and see if any of the cylinders are causing the problem. If it's not the spark plugs it could be a vacuum leak.
Start pulling the plugs Kirk. See what they all look like. After that start checking the coils as stated above. Sounds like a miss-fire more so than a fuel problem. Unless the cars underwater I think you got enough air.
Well, the car has 81k miles on it and the spark plugs have never been changed. I guess ill be doing that this weekend. Should I just stay with the stock platinum plugs or go with another set?? What is stock spark plug gap for a 2002 gt (I haven't looked that up yet)?
Also, if it was a COP how would I know when pulling them off there was a problem. With plugs atleast I can see they are worn on the tips or have deposit on them...
Thanks,
Kirk
Sounds like tune up time to me. New plugs, some seafoam, a little Lucas fuel treatment, and some new oil, and you should no longer have a problem. 81k on stock plugs....I wonder what those electrodes look like.
like someone said above... pull each coil pack one at a time and see which one doesnt change the way the car runs.... now you know the cylinder. pull the pack and check for any moisture. Then pull plug and check for it to be soaked in gas which will not allow for it to fire. If so try replacing the plugs. If this does not work then get a stethoscope and listen to injector and make sure it is pulsing.
Hope this helps good luck
It would be hard to see a change in how the motor is running with this problem because it only occurs while driving under load at lower rpms. I'm going to change the plugs this weekend. Let me know if there are any tricks with changing them on the stang
So i replaced my spark plugs looked over everything carefully. I believe that the PCV is ok but I did not pull it out because I believe 2001 models you have to unbolt the valve cover which is a little too intense for me to take on right now.
I did notice after alot of looking over the engine that on the drivers side there is a hose that goes into the top of that valve cover. The grommet or seal around it looks like it has let some oil residue out and one of the spark plugs on that side of the engine had a little oil residue as well.
What is this part and how easy is it to replace? Could this be my problem?
Kirk
I had the same problem... it started only at high RPMs... I checked the spark plugs, all OK... I checked the impedance on all coils, all OK...
Last week it started to happen at low RPM's as well but only when my gas tank was below 3/4 full...
I replaced the fuel pump... the suction strainer was plugged. I could had changed the strainer only but I replaced the whole fuel pump instead because of the mileage (131,000 miles.)
Fuel pump replacement is an afternoon job.
Cheers, Ric.
Cheers, Ric.
I was able to resolve my problem. I paid 65 bucks to have my car hooked up to ODBII to tell me whats wrong though :(
one of my ignition coil's were bad. 66.99 on top of that Ouch.
Oh well, it beats the hell out of having a leaking pile of an engine which is always a possibility at higher miles.
Kirk
