sub frame help
  • Thread starter Thread starter StonysGT
  • Start date Start date Feb 3, 2004
StonysGT
220
winamac, Indiana
Feb 3, 2004
  • Feb 3, 2004
i just bought some subframe connector. should i weld them or bolt them. they were suppose to be custom made for my conv. but i didnt know if it was something i could do my self or not. also if i need to weld them how should i go about keeping them from rusting cause ill be pissed if they start rustin bad.
StonysGT
220
winamac, Indiana
Feb 3, 2004
  • Feb 3, 2004
hello any one with suggestions.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Feb 3, 2004
  • Feb 3, 2004
Weld in, bolt in just doesn't work well.
cevtv
1,113
Massachusetts
Feb 3, 2004
  • Feb 3, 2004
Bolting them in is a waste of time, weld them. Paint over the welds to keep them from rusting.
hamonkeiser
290
Lancaster, PA
Feb 3, 2004
  • Feb 3, 2004
Weld them, Bolts will stretch over time. Like said before paint over the welds
Black 93 Fox
1,995
Vancouver,Washington
Feb 3, 2004
  • Feb 3, 2004
Sorry got here a little late. Weld diffently and paint over the welds like said many times befor.
Later,Black 93 Fox
P.S. If you need any other help with the smog pump delete or anything shoot me a im.
G
goldbomb79
374
Indiana
Feb 3, 2004
  • Feb 3, 2004
yep, weld is the way to go. after you weld them on clean the weld up and paint the welds. I also undercoated mine after i painted them.
9
9 Deuce GT
550
Geneva, NY
Feb 4, 2004
  • Feb 4, 2004
Weld them they will be stronger. Just put paint on them after you weld them.
siege
651
Peoria, AZ
Feb 4, 2004
  • Feb 4, 2004
I've also heard if you're really concerned about rust, use a weld-through primer first..there's a thread about this somewhere on here....
oldskolbus
258
WV
Feb 4, 2004
#10
  • Feb 4, 2004
  • #10
Weld them in. A firend of mine bolted his in and the holes look like ovals now. This is the same friend who had cracks in the a pillars(top of the windshield). I guess he got the front tires off the ground one too many times.
P
PonyBoy90
555
Toronto
Feb 4, 2004
#11
  • Feb 4, 2004
  • #11
I take it these bolt to the seat bolt right? If so, bolt them in tight, and then weld. Finally paint.
After 24 hours, spray a can of Rust preventive oil on the subframes. Depending on how often you drive the car in the rain, re-spray them with the rust proofing oil every once in a while. If it's dry where you are, twice a year is all that's necessary. More so if it rains more often.
StonysGT
220
winamac, Indiana
Feb 4, 2004
#12
  • Feb 4, 2004
  • #12
thanks alot everyone i appreciate your answers.
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
E
New Member with 91 foxbody
  • EricMac13
  • Jul 22, 2025
  • The Welcome Wagon
The Welcome Wagon Jul 23, 2025
EricMac13
E
Torque box reinforcement with cage?
  • DeathProof88
  • Jan 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 6, 2025
DeathProof88
Can makes noises when driving poping
  • Creomod
  • Oct 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2025
Creomod
