Sub frame install questions
drewzx3
411
Louisiana
I'm about to get a set of mm subframe connectors and I was wondering can I use an arch welder to weld them in? Also I have a lift but it has posts not a drive on. Can I use it to weld them in or not?
I would definitely not want to install them without a drive on lift :nono:
You really need the vehicle to be at rest :nice:
If it's lifted any other way the body will be flexed to some degree and that will become the new stance once the subframes are welded in :(
use 4 tall jackstands and put 2 on the back axle, and one on each of the front control arms to mimic the car sitting on the ground??
And how do you know with certainty that one side or corner isn't higher/lower or somewhere other than where it should be if it was sitting on the ground :shrug:
If it were my car I would just do it the correct way :)
actually even a little bit off can flex the chassis, then you weld reinformcent permenmentaly flexing teh chassis which can lead to uneven tire wear, allignment issues and basicly a ruined mustang.
your call.
I did mine in the garage...
two jackstands under the axle and 2 jachstands on the frame rails jsut under the front of the doors... the whole nose flexed down doing htis therefore straightening it out... Doing this fixed my door gaps....
For welding I used a MIG with fluxcore wire. Not the neatest but they are holding up good so far...
