Both O2 sensors are the same. If somehow the wiring connectors were plugged into the wrong side, crossed over, it would be very apparent. That could cause some strange behavior.
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See
http://www.troublecodes.net/Ford/
OR
See
http://www.dalidesign.com/hbook/eectest.html for more descriptive help
OR
See
http://www.mustangworks.com/article...c-iv_codes.html
IF your car is an 88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see
http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart .
