Surge/hesitation After Plugs
It is at 45 psi, but (I believe, I am trying to remember what I was told a few days ago, and this problem has me frustrated to the point i'm forgetting) with the regulator disconnected (to test the fuel pump's flow unregulated, to check pump flow) it shot up to 80 or so.
It's at the shop now. A new fuel pump didn't fix it either, although it is fluctuating less. Short of PCM/CCRM fixing it it looks like I'll be buying a car later this week :(
Well, 1/2 problems down, lol.
After getting a new PIP sensor (was half ground off!) and fuel pump, the car now idles and actually runs without stalling, back to it's 'normal' self. But I am back to my post #1 issue. Hesitation around mid 2000 rpms, when warm, usually under load. It's also running real rich (smell in drivers seat, quite strong), and has a very rare backfire at idle (usually after it's first start up, not in traffic).
I hate to ask again (and again... and again....) but any ideas / directions to look at for a rich running engine hesitating @ 2500ish rpm? New plugs, wires, coil pack, cap, rotor, TFI, fuel pump, MAF, PIP, IAC cleaned, fuel pressure in spec
I have had no codes through out all of this. KOEO/KOER or stored, just 1-1-1's. When the ignition pickup was going it took ages to pull KOER but is back to normal with it replaced.
I do not know how old the o2's are, which means at 100k miles it's probably safe to change them anyways. I was told o2's have no effect on WOT and I tried 2 pulls last night for a test, no hesitation/sputter anywhere in the tach, looks like they be coming out next!
WOT (about 75% throttle) is open loop with the ECU relying exclusively on the fuel map. Below that threshold is closed loop and the fuel is being managed based on the fuel map and the signal from the O2 sensors.
Reactions: Dacon
Cylinder balance test: use this to find dead or weak cylinders:
Revised 25 March 2012 to add necessity allowing the KOEO tests to finish before starting the engine and the need for a properly functioning IAB/IAC to run the cylinder balance test.
The computer has a cylinder balance test that helps locate cylinders with low power output. You’ll need to dump the codes out of the computer and make sure that you have the A/C off, clutch depressed to the floor and the transmission in neutral. Fail to do this and you can’t do the engine running dump codes test that allows you to do the cylinder balance test.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C clutch depressed to the floor, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Here's how to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and drivability problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, clutch depressed to the floor and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
If you have idle or IAC/IAB problems and the engine will not idle on its own without mechanically adjusting the base idle speed above 625-750 RPM, this test will fail with random cylinders pointed out every time it runs. The IAC/IAB must be capable of controlling the engine speed to run in the 1400-1600 RPM range. Playing with the base idle speed by adjusting it upwards will not work, the computer has to be able to control the engine speed using the IAC/IAB.
Warm the car's engine up to normal operating temperature. Use a jumper wire or paper clip to put the computer into test mode. Let it finish the Key On Engine Off (KOEO) code dump. Start the engine and let it go through the normal diagnostic tests, then quickly press the throttle to the floor. Remember to keep the clutch pedal (5 speed) depressed to the floor during the test. The engine RPM should exceed 2500 RPM's for a brief second. The engine RPM's will increase to about 1450-1600 RPM and hold steady. The engine will shut off power to each injector, one at a time. When it has sequenced through all 8 injectors, it will flash 9 for everything OK, or the number of the failing cylinder such as 2 for cylinder #2. Quickly pressing the throttle again up to 2500 RPM’s will cause the test to re-run with smaller qualifying figures.
Do it a third time, and if the same cylinder shows up, the cylinder is weak and isn’t putting out power like it should. See the Chilton’s Shop manual for the complete test procedure
Do a compression test on all the cylinders.
Take special note of any cylinder that shows up as weak in the cylinder balance test. Low compression on one of these cylinders rules out the injectors as being the most likely cause of the problem. Look at cylinders that fail the cylinder balance test but have good compression. These cylinders either have a bad injector, bad spark plug or spark plug wire. Move the wire and then the spark plug to another cylinder and run the cylinder balance test again. If it follows the moved wire or spark plug, you have found the problem. If the same cylinder fails the test again, the injector is bad. If different cylinders fail the cylinder balance test, you have ignition problems or wiring problems in the 10 pin black & white electrical connectors located by the EGR.
How to do a compression test:
Only use a compression tester with a screw in adapter for the spark plug hole. The other type leaks too much to get an accurate reading. Your local auto parts store may have a compression tester to rent/loan. If you do mechanic work on your own car on a regular basis, it would be a good tool to add to your collection.
With the engine warmed up, remove all spark plugs and prop the throttle wide open with a plastic screwdriver handle between the throttle butterfly and the throttle housing. Crank the engine until it the gage reading stops increasing. On a cold engine, it will be hard to tell what's good & what's not. Some of the recent posts have numbers ranging from 140-170 PSI. If the compression is low, squirt some oil in the cylinder and do it again – if it comes up, the rings are worn. There should be no more than 10% difference between cylinders. Use a blow down leak test (puts compressed air inside cylinders) on cylinders that have more than 10% difference.
I generally use a big screwdriver handle stuck in the TB between the butterfly and the TB to prop the throttle open. The plastic is soft enough that it won't damage anything and won't get sucked down the intake either.
A battery charger (not the trickle type) is a good thing to have if you haven't driven the car lately or if you have any doubts about the battery's health. Connect it up while you are cranking the engine and it will help keep the starter cranking at a consistent speed from the first cylinder tested to the last cylinder.
PM me for details on how to build your own blow down type compression tester.
Reactions: Dacon
Well, the o2's did nothing and now it won't start, lol. Is it possible the pick up sensor is already bad / a bad distributor faulted the new pick up sensor in 2 weeks ? Had it for 2 weeks, drove it 4 times and now it cranks normal/strong but no catch/run, not even a stumble. The last drive I did notice a strong tick in tune/speed with engine RPM's, but the all wires and plugs are good.
Fuel pressure present. Battery is brand new, negative terminal was loose when tight so tossed a new terminal on and it just cranks. Didn't check to see if plugs had spark as I don't have a second to start car.
Cranks OK, but No Start Checklist for Fuel Injected 5.0 Mustangs model years 1986-1995
A word about this checklist before you start: it is arranged in a specific order to put the most likely failure items first. That will save you time, energy and money. Start at the top of the list and work your way down. Jumping around will possibly cause you to miss just what you need to see to find and fix the problem. Don’t skip any steps because the next step depends on the last step working correctly.
Revised 15-Sep-2014 to add temporarily bypassing the MSD box if it is present.
1.) Remove push on connector (small red/blue wire) from starter solenoid and turn ignition switch to the Run position. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
Bypass it and return to stock configuration if possible. Do this as a temporary measure to eliminate it as a possible problem source.
B.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed. See paragraph 5A – Using a noid light will tell if the PIP is working by flashing when the engine is cranking.
C.) TFI module: use a test light to check the TFI module. Place one lead of the test light on the red/green wire on the ignition coil connector and the other lead on the dark green/yellow wire on the ignition coil connector. If the TFI is working properly, the test light will flash when the engine is cranked using the ignition switch.
D.) Coil
E.) No EEC or computer power - EEC or computer relay failure
86-93 models only: EEC relay next to computer - look for 12 volts at the fuel injector red wires.
Both 86-93 and 94-95 models: No 12 volts with the ignition switch in the run position on the fuel injector red wires. The relay has failed or there is no power coming from the ignition switch. Make sure that there is 12 volts on the red/green wire on the coil before replacing the relay.
F.) No EEC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid. Look for a 20 gauge blue fuse link connected to 2 black/orange 14 gauge wires.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire on the ignition switch with it in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position at the ignition switch but not at the coil, then the fuse or fuse link is blown.
Note: fuses or fuse links blow for a reason. Don’t replace either a fuse or fuse link with one with a larger rating than stock. Doing so invites an electrical fire.
Ignition fuse links may be replaced with an inline fuse holder and 5 amp fuse for troubleshooting purposes.
H.) Missing or loose computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery.
In 86-90 model cars, it is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire.
In 91-95 model cars it is a black cylinder about 2 1/2" long by 1" diameter with a black/white wire.
You'll find it up next to the starter solenoid where the wire goes into the wiring harness
I.) Computer. Don’t replace the computer just because you don’t understand how it works. Computers seldom fail, it usually is a sensor or wiring problem that causes the problems.
J.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
K.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red/blue wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI. No 12 volts, replace the ignition switch.
Wiring Diagrams:
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
AutoZone wiring diagrams: You can navigate to the diagrams yourself via Repair Info | AutoZone.com and select the car year, make, model and engine. That will enable you to bring up the wiring diagram for your particular car.
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability: [/b]
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 2-4 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
attachment.php
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) The PIP sensor in the distributor tells the computer when to fire the injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed.
A noid light available from any auto parts store, is one way to test the injector circuit to see if the injectors are firing. The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and try to start the engine: it will flash if the injector is firing.
I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
B.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
C.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
See the graphic for the 10 pin connector circuit layout.
salt-pepper-10-pin-connectors-65-jpg.68512
The injector power pin is the VPWR pin in the black 10 pin connector.
D.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the EEC relay and the red wire for the 10 pin connectors.
E.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.1.0 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB or improperly set base idle (no airflow to start engine). Press the throttle ¼ way down and try to start the car. See the "Surging Idle Checklist for help with all your idle/stall problems.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently. If you removed the distributor, there is a good probability that you installed it 180 degrees out of time.
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
Reactions: Dacon
Heh, when the PIP was installed the pins in the connector ended up bent/not connected. That's fixed, car starts, runs good.
Except for the surge when holding steady @ 1500-2200rpm or accelerating in that spot.
New O2's (had original's @ 102kmiles), new ECT sensor, got my silverfox valvebody in (tranny shop said they do not believe problem is transmission). It's at a shop right now, they are going to wiggle test connectors cause I'm losing it/don't have enough skill to solve this one.
Electrical maybe? I did replace the headlight switch pigtail as most need to, if it has a loose connection after could that cause a voltage drop/my symptoms ?
I replaced my front calipers with the SVE cobra 2 piston calipers/13" rotor, but with factory brakes and new calipers/rotors my brake pedal would randomly rebound stiffly just as I was about to brake before reversing into a parking stall. It's only done it 5-6 times in 4000km (very rarely). It is stiff only for a fraction of a second, enough for me to barely feel it, before returning to normal. Could that be a leaking brake booster / minor vacuum leak that's creating it ?
The car was hooked up to a scope, but never changed readings when it was hooked up. The scope then gave out / needed a part itself. My car is now trying to kill shop equipment.
Only the plugs /pigtail and switch were changed prior to this problem starting, maybe I'm just unlucky and it's a broken wire there and I'm throwing money at nothing.
Hahahaha it goes on and on.
It's nothing electrical like I thought it might be. I realized it is happening in 2nd only, so I took it to a reputable transmission shop. Everything I said, what it does / what I've done to fix it they say corresponds to a potential transmission issue. After a test drive THEY think it is a fuel issue, although it could be a failing diode that would require a transmission drop just to check. My mechanic is waiting to get his scope fixed, I'm in limbo till then.
Is it normal to have wished for a diagnosed transmission problem ? It would have helped to fix this, that's for sure. Had the cash for a turbo burning a hole in my pocket, can't do it with this problem.
Without going back through all the posts, has the FPR been checked? You made somewhere a reference to the psi @ 80-90. The only way for that to happen is if the return line is plugged or the FPR isn't releasing the excess fuel back into the return line. Is the vacuum line to the FPR connected and no breaks in the line?
Reactions: Dacon
Fuel pressure was at 39-40, lines were removed and cleared when the new pump went in. I believe the 80psi was just the pump pushing gas into a jerry can with the lines not even running to the engine (I didn't swap pumps, shop did), tested to see if maybe the fuel pump was weak but it was not. FPR was ruled out, another unit was tried and had no change. I've also read FPR's are either good or bad there is usually no cold/warm related issue to it. That makes me lean towards transmission as the engine/fluid heats up the problem begins. But I've leaned many ways on this problem, would kill for it to throw a code (no code is also making me think transmission)
Bear in mind I am not 100% of the 80 or the test for it (I did the ignition stuff, did not touch fuel pump / lines the shop did), I just remember them saying with the FPR disconnected and fuel pump free flowing it shot up to a high number (80 is what I keep remembering), verifying the pump was healthy. On the shrader (I believe) it was 39-40
Well I'll be damned.
Pulled parts / receipts to check part numbers for anything I've replaced since my problems started. The ignition control module's # matched no known part # (or alternative #) for ANY mustang, and the manufacturer said 'nope we don't make one at all with that #!" even though I was holding it and can still see the number. And it drove my car fine except in 2nd. Not bad for a ignition control module nobody apparently made.
Basically, trying to solve my original problem, I created a new one. After solving the original problem, I found the new problem which was a part I put in in hopes of solving the original problem. Another downside to dartboard mechanics...
Happy day. Some new suspension bits from MaximumMotorsports this month to help put power down, and then I'm getting new On3 turbo kit can't beat that price :D
