Swap Complete Just Need Some Computer Help
Mjm716
I just finished swapping my auto for manual in my 200gt. car runs and drives fine with the auto computer. I want to swap in a manual computer and I got one from craigslist and its was a JRX0. when I installed it just turned the fan on. I tested all grounds and computer seems to be dead. I want to purchase another one from ebay but I need to know which are compatible? or did I miss something I should do when installing a manual trans computer. dealer even tried to program JRX0 computer and they said it was dead. any help would be appreciated
wmburns
SN Certified Technician
Aug 14, 2009
5,894
521
204
Houston Texas
There's a difference between a "dead" PCM and a non-compatible PCM. When the cooling fan runs all the time, that's a sign of no power to the PCM or a bad PCM.
Sounds like you have a bad Craigslist PCM.
As far as which one is compatible, my recommendation is to get a PCM from a 2000 GT manual. I would not recommend using a 2001+ because of wiring changes.
If you must use a PCM from a different MY, look only at the 1999.
Search car-part.com for other sources of salvage yard PCM's in your area.
