swap done now what ?
Cone filter and turn up the boost to 17-18 (pushing the a4ld a bit) maybe 16. If you have the funds do the 3" downpipe and exhaust. You will want to get rid of the one legger rear end too. You can slap a traction lock differential in there from an Aerostar, Ranger, Turbocoupe and a couple others.
ok i got a k&N cone filter right after the VAM..... i put some bosch platnium2 plugs in it and got some good wires and did a ful tune up..... now how do i increase the turbo boost ?
i am gonna order a full 3" exhaust soon i think i am gonna have some side pipes made for my car..... kinda like the z-28 tips but one on both sides near the rear tire !
Hold on, what kind of tune up did you do? Platinum plugs are a BIG no no on a turbo motor! What plugs wires are you running?
Im not gonna tell you how to turn up the boost until you get the little things done mister! gonna go blow your bottom end out the tailpipe ;)
our turbo motors are picky, but in a good way. they love cheap coper core motorcraft plugs and and motorcraft wires. If you dont do a motorcraft tuneup, chances are 95% of the time you will have problems , such as misses..bad idle, detonation ...etc. Ford designed these cars...and they are the exception becuase they really only do well with OEM ignition equipment.
do the accel ignition systems help much with our turbo motors ?
my plans so far are guttin upper and lower intake.....
port heads
3" exhaust
maybe have the ihi turbo rebuilt.....
front mount intercooler
also would like to make some sort of ram air setup for my car
Platinums burn to hot!!! Will melt piston tops! Run motorcraft or autolights gapped at 32. Use all ford cap, rotor button,cap and the factory coil will do you the best over the rest.
Also use Ford wires. I know it's expensive stiick with high test gas.
A set of brown tops or better if you aint got them. You look around you can get a set cheap!!!
An adjustable fuel pressure regulator and a 225 lph fuel pump. By then you will be ready for the t-5 because you will need it!!
