Hey guys, I am in the process of restoring the '84 Fox body stang that has been in my family longer than I have and I was wondering if you guys might have any tips, shortcuts or ideas that might help me out. Right now the old V6 (3.8 Litre I believe) has been pulled and I have washed out the engine bay.
I am going to be putting in a high-output 302 5.0L V8 and I know I will have to change the configuration of the motor mounts. Does anyone here have a decent idea as to how I should do that?
Also, I am going to put in a new high performance coil and a bigger alternator and I am going to try and hang on to the old power steering pump. I may have to buy a new water pump and thermostat housing if I don't pull the ones off of my other '83 stang. The guy I bought the engine from told me I will need a new distributor as well which can run as high as $160-$200 Canadian
. There was something in particular related to the distributer that would only allow for a special type of distributer to be used if I remember corectly. I think it was because the camshaft was a special roller cam and the distributer had to match? I really don't have the information with me, but maybe you guys know what I am getting at?
I pulled the tranny off the old V6 and matched it up to the new block and found that it fits just fine (thank God for that!) so I will save a few bucks on a new transmission hopefully! Any other tips and tricks as far as the engine and accessories go are welcome!
As for body detailing I will be using Aircraft Stripper to remove the paint, primer, etc. and I will be painting the unit cherry red. All of the rust will be bondo'd. There is quite a bit of rust, but not in huge gaping holes, just a little patch here and there. Any tips on fixing rust damage and preventing future rusting are welcome.
I am also going to be mounting a hood scoop and I would like to flair out the fenders a little bit as well, but that will come much later so tips on body detailing are also welcome!
That about sums it up for now. I will try and add pics later. If you guys need more information please ask and I will try and get it ASAP. I am also looking for parts, so if you guys know of any good places or deals let me know!
Thanks alot guys!
. There was something in particular related to the distributer that would only allow for a special type of distributer to be used if I remember corectly. I think it was because the camshaft was a special roller cam and the distributer had to match? I really don't have the information with me, but maybe you guys know what I am getting at? I pulled the tranny off the old V6 and matched it up to the new block and found that it fits just fine (thank God for that!) so I will save a few bucks on a new transmission hopefully! Any other tips and tricks as far as the engine and accessories go are welcome!
Thanks alot guys!
Thanks for the link tho.
