I was under there the other day changing the rearend fluid and noticed the 4 banger didnt have a rear sway bar? I did'nt really noticed it wasent there as far as the way it handled, does anyone have one to get rid of? Shurly this wasent an option ? Will one from a 95 work? peace
john
john
gospeedgo
Banned
SMOKEDYA said:Shurly this wasent an option ? Will one from a 95 work? peace
It came on V8 cars only (unless it might have been ordered or something, not normally on 4's) and a 95 one should work. Quad shocks should be missing too.
I didnt even noticed the quads are or is missing, since i havent seen a car with them on it in awhile? If they are then that explains the wheel hop when i did that last power brake in itgospeedgo said:It came on V8 cars only (unless it might have been ordered or something, not normally on 4's) and a 95 one should work. Quad shocks should be missing too.
john
LordMustangGT
if not I got a rear GT one too that will work, but the 95 one should work. They use, and don't use alot of stuff between the two, I went from 4 banger to V8. The 4 bangers have a weeker and smaller 7.5 rear with no limited slip too.
Yep knew and found that out! One tire frierLordMustangGT said:if not I got a rear GT one too that will work, but the 95 one should work. They use, and don't use alot of stuff between the two, I went from 4 banger to V8. The 4 bangers have a weeker and smaller 7.5 rear with no limited slip too.
john
LordMustangGT
SMOKEDYA said:Yep knew and found that out! One tire frierfummy you say this cause just today i was thinking of doing gears in it! But then thought **** this is a D/D and is suppose to be for gas milage peace
john
Ya I pulled my stock 7.5 out and threw a 84 turbo coupe 7.5 in and it had limited slip. work great till i got some wheel hop on a corner and blew all the internals. good times,....
matt
- Replies
- 7
- Views
- 466
- Replies
- 4
- Views
- 353
- Replies
- 2
- Views
- 871
- Replies
- 4
- Views
- 399
