Sway bars
SMOKEDYA
Jul 13, 2003
3,637
Tucson AZ
I was under there the other day changing the rearend fluid and noticed the 4 banger didnt have a rear sway bar? I did'nt really noticed it wasent there as far as the way it handled, does anyone have one to get rid of? Shurly this wasent an option ? Will one from a 95 work? peace
john:p
gospeedgo said:
It came on V8 cars only (unless it might have been ordered or something, not normally on 4's) and a 95 one should work. Quad shocks should be missing too.
I didnt even noticed the quads are or is missing, since i havent seen a car with them on it in awhile? If they are then that explains the wheel hop when i did that last power brake in it :D Thats cool i'll get the one off the 95 then to see. Thanks. peace
john:p
LordMustangGT said:
if not I got a rear GT one too that will work, but the 95 one should work. They use, and don't use alot of stuff between the two, I went from 4 banger to V8. The 4 bangers have a weeker and smaller 7.5 rear with no limited slip too.
Yep knew and found that out! One tire frier :rlaugh: :banana: fummy you say this cause just today i was thinking of doing gears in it! But then thought **** this is a D/D and is suppose to be for gas milage :nonono: peace
john:p
john:p
Ya I pulled my stock 7.5 out and threw a 84 turbo coupe 7.5 in and it had limited slip. work great till i got some wheel hop on a corner and blew all the internals. good times,....
matt
