T-45 fluid Qs
stangen97 said:
Ok I picked up rp atf max and they had another bottle like senchromax (recomended for ma nual trannies that require atf) it said smother shifting ect ect. Well i think im going to take the atf max back for this stuff.
NO, use max ATF, it is a dexron/mercron based fluid which is what the tranny calls for.
awwyea said:
Alldata DIY website sez the Syncromesh from GM should only be used in the 3650, not recommended for the T45. Royal Purple is the only way to go. Worth the $$$$.
Hummmm, Alldata DIY sounds to have made a mis-print or typo on that info, Tremec themselves says NOT to use GM Syncromesh in the 3650 because that fluid will cause the syncronizers to swell and ruin them. :shrug:
Pughman said:
tell me how much it takes ...
3.2 qts
I changed mine yesterday, an easy/no mess, way to do it is to take out both plugs, drain it, install botom plug. then I take the shifter off and fill in the shifter hole. At the 4th qt. i pour really slow untill i see/hear a trickle runing into the catch pan. then button up the shifter, install fill plug and good to go.
