  • SN95 4.6L Mustang Tech
T-45 issue
  • Thread starter Thread starter Skidzz
  • Start date Start date Feb 18, 2006
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
Feb 18, 2006
  • Feb 18, 2006
Ok, I know these trannis have a problem with grinding gears, but I noticed tonight that everytime I shift from 3rd to 4rd hard, it grinds. It doesn't matter how long I've been driving it. Am I just never supposed to shift hard from 3rd to 4th? When I have my work done at MD, I'm going to have the tranni fluid changed to royal purple ATF. Will that help? I hope so, because this sucks.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Feb 18, 2006
  • Feb 18, 2006
is it only 3-4? a lot of times the clutch cable is not adjusted right, so there is not enough of a air gap. so your shifting with the clutch parlty engaged, not a problem untill you try to shift fast at high rpm's
but this might not be your problem this would happen in other gears to.
R
Red2000GT
2,450
Regina,Sask.Canada
Feb 18, 2006
  • Feb 18, 2006
The synthetic tranny fluid will help but if it doesn't go away then it's probably synchro's. They are known to be weak on the t-45's.
Shiroelex
There's nothing worse than aut
728
Westland, MI
Feb 18, 2006
  • Feb 18, 2006
I've noticed that sometimes in my T45 as well. I usually just take a split second's time longer on that gear, to push the clutch all the way down, and pull it into gear all the way. It takes some getting used to, but I never grind anymore. Honestly, I think I noticed it grinding more after I did the IAC mod.
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
Feb 18, 2006
  • Feb 18, 2006
No, it does it in 1-2 and 2-3 when the tranni is still cold, but the 3-4 does it ALL THE TIME. And no the clutch it fully engaged when it does it.
Mike97gt
it doe snot
10,633
Feb 18, 2006
  • Feb 18, 2006
just because the pedal is too the floor does not mean the clutch is disengaging. where is the engagement point start. the min. is 1 inch from the floor.
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
Feb 18, 2006
  • Feb 18, 2006
I'd say it's an inch from the floor if not closer to the floor.
Mike97gt
it doe snot
10,633
Feb 18, 2006
  • Feb 18, 2006
anything closer than 1 inch is bad. i personally think even 1 inch is to close. i would get a quadrant and firewall adjuster.
i used to have the same problem with my T-45 then i adjusted my clutch better and it that fxed it.
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
Feb 18, 2006
  • Feb 18, 2006
Where is a good place to get those?
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
Feb 18, 2006
#10
  • Feb 18, 2006
  • #10
Nevermind, mustangtuning has them both.
timeless2
Vi Veri Veni Versum Vicus Vici
Admin Dude
202
154
the Shadow Gallery
Feb 18, 2006
#11
  • Feb 18, 2006
  • #11
partshopper.com
brenspeed.com
mustangtuning.com
Mike97gt
it doe snot
10,633
Feb 18, 2006
#12
  • Feb 18, 2006
  • #12
there are many options for the quad and adjuster. i do recomend you stay with the stock cable. well a new stocker that is. i am not to happy with the adjustable aftermarket cable. the steeda kit i have came with the hardware needed to use the stock cable.
ironmedic
1,361
Puyallup, WA
Feb 18, 2006
#13
  • Feb 18, 2006
  • #13
yeah i get that nice 2nd gear grind when the tranny is cold. happens once and once only almost every other day and what not. happened on my 89GT with the T-5. came to the conclusion that synchros suck LOL!
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
C
Trans issues.
  • ChrisCruz1972
  • Aug 13, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
slow84lx
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
