T-45 issue
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
Ok, I know these trannis have a problem with grinding gears, but I noticed tonight that everytime I shift from 3rd to 4rd hard, it grinds. It doesn't matter how long I've been driving it. Am I just never supposed to shift hard from 3rd to 4th? When I have my work done at MD, I'm going to have the tranni fluid changed to royal purple ATF. Will that help? I hope so, because this sucks.
I've noticed that sometimes in my T45 as well. I usually just take a split second's time longer on that gear, to push the clutch all the way down, and pull it into gear all the way. It takes some getting used to, but I never grind anymore. Honestly, I think I noticed it grinding more after I did the IAC mod.
svttech76 said:
is it only 3-4? a lot of times the clutch cable is not adjusted right, so there is not enough of a air gap. so your shifting with the clutch parlty engaged, not a problem untill you try to shift fast at high rpm's
but this might not be your problem this would happen in other gears to.
No, it does it in 1-2 and 2-3 when the tranni is still cold, but the 3-4 does it ALL THE TIME. And no the clutch it fully engaged when it does it.
