I have done a search, and read lots of check lists and i'm stumped. My wiring must be wrong somewhere and im hoping someone can help.
Scenario is car is an 89 LX 5 speed 5.0. Car ran find when taken apart. We pulled the motor to change all the seals, and we installed an AOD. I plugged the AOD harness into the body of the car, disconnected the 2 plugs for the clutch switch and jumped 1 of the plugs with the 2 red/lt blue wires. Also there was a remote start which i unwired and re-connected the wires that were cut. The only other 2 things done were a heater core, and a 130amp alternator.
After installing the engine and trans, car will tun over, but no fuel pump prime.
I checked through this thread for testing proceedures: https://www.stangnet.com/mustang-forums/threads/no-fp-prime-no-koeo-light.897747/#post-9048307
In this thread, at this point i see 3 volts at the tan/lite green wire, NOT less then .75 volts. Jumping pin 22 and i do have a glow. However when i put the computer in self test mode to dump codes, the light does not flash.
The Tan/Lt Green wire provides a ground path for the relay power. With the test connector jumpered to ground, there should be less than .75 volts. Use a test lamp with one side connected to battery power and the other side to the Tan/Lt Green wire. The test light should glow brightly. No glow and you have a broken wire or bad connection between the test connector and the relay. To test the wiring from the computer, remove the passenger side kick panel and disconnect the computer connector. It has a 10 MM bolt that holds it in place. With the test lamp connected to power, jumper pin 22 to ground and the test lamp should glow. No glow and the wiring between the computer and the fuel pump relay is bad.
Also, i played swaptronics and swapped in another A9L computer - same thing. so i know its my wiring or something somewhere. Any help would be great cause i'm at a complete loss
