I called a Mustang only store and explained that I was doing a T5 conversion on a 65 Mustang. It is a 4 speed car already. The guy told me that all I needed was the adaptor plate for the bell housing and the crossmember. He said the slip yokes were the same and the original trans mount was retained.
Well , the slip yokes are not the same and the trans mount will not work. The trans mounts hight prevents it from fitting in between the crossmember and the trans , even if the trans is jacked into the floorboards. The original yoke is too small for the T5. I have the T5 yoke , but the local parts store can't come up with a u-joint that will mount the new slip yoke to the old driveshaft. The trans is out of a 93 Mustang , if it matters. This bites big time because the car is stuck on my lift at work. Can anyone shed some light on this??? I did a search and saw several pictures of what is needed for the swap and they all showed a mount and a slip yoke. I have a Mustangs Unlimited crossmember if it matters.
THANKS !!!!!!!!!!
THANKS !!!!!!!!!!
