  • 1994 - 1995 Specific Tech
T5 experts
  • Thread starter Thread starter igotyofire
  • Start date Start date Jul 7, 2005
I
igotyofire
774
Southern California
Jul 7, 2005
  • Jul 7, 2005
It is to my understanding that the 94-95 cobras and GT both have the T5 but i heard in the Cobras that somthing was coated on the Cobra version of the tranny(possibly synchros?), Is this true? ALso what is this small difference and does it make it stronger. Do the t5 rebuild kits have this piece that is different also? the 94-95 t5 trannies are rated at 300lbs of torque or 330 i always get confused
5.0_GT_kid
20+ Year Stangneter
Apr 18, 2004
1,155
Largo, Florida
Jul 7, 2005
  • Jul 7, 2005
Subscribing for info. I also have heard about differences in Cobra T5 but not sure if it's true.
I
igotyofire
774
Southern California
Jul 7, 2005
  • Jul 7, 2005
oh i know its true, just i dont know whact is exactly different, and if rebuild kits contained these differences because i never see it specified
WhiteDevil
2,717
San Diego
Jul 7, 2005
  • Jul 7, 2005
Its not worth much talking about. They are all very weak transmissions. I havent seen it talked about in any rebuild kits so it must not be worth it. I believe that 95 cobras had a steel bearing retainer, which is better than the aluminum ones that the GTs come with, dont quote me on that though.
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
Jul 7, 2005
  • Jul 7, 2005
#1.) The Cobra T-5 has stronger bearings that are true roller bearings. It has Timken tapered roller pocket bearings.
#2.) The Cobra T-5 has phosphate coated gears.
#3.) Not sure, but I've heard some say the Cobra T-5 has a lower 1st gear. I dunno... but I think they have the same 3.35 gear as the GT.
Redsnk95
2,243
Houston, TX
Jul 7, 2005
  • Jul 7, 2005
The above post is correct in all respects...3.35 first gear.
Troy
WhiteDevil
2,717
San Diego
Jul 8, 2005
  • Jul 8, 2005
SO why are there no cobra specific rebuild kits? I never seen anything like that. I know that its just the bearings but how is that giong to make it any stronger. The stress is on the gears themselves and the clutching teeth to some degree. I dont see how a better bearing will make it stronger, smooth sure, but not any stronger.
J
jasonlee0704
219
Kansas City, MO
Jul 8, 2005
  • Jul 8, 2005
Ford Racing offers a T-5 rebuild kit and also sells the specific input and speed gears needed to upgrade a normal T-5 to World Class (330 ft.-lbs. torque capacity). The only downside is that the gear ratios move slightly lower numerically.
Cobra ratios:
1st - 3.35
2nd - 1.99
3rd - 1.33
4th - 1
5th - 0.68
World Class ratios:
1st- 2.95
2nd - 1.94
3rd - 1.34
4th - 1
5th - 0.63
SeventyMach1
Mar 30, 2005
1,940
North Carolina
Jul 8, 2005
  • Jul 8, 2005
You really answered yourself on that one. That's why you don't see Cobra specific rebuild kits..... because it wasn't "really" any stronger. Plus there are so many other better upgraded rebuild kits.... what would be the point in making/selling the Cobra specific one?
WhiteDevil
2,717
San Diego
Jul 8, 2005
#10
  • Jul 8, 2005
  • #10
True, i dunno i just figured people would want to have the "cobra" or something. It it was really a better thing, but yea i guess i did answer my answer my own question.
I
igotyofire
774
Southern California
Jul 8, 2005
#11
  • Jul 8, 2005
  • #11
so then im assuming stock 94-95 T5s are rated at 300lbs and rebuild kits are made for 330lbs or what? or different gear sets are rated at 330? And so that means we dont have the world class tranny?
WhiteDevil
2,717
San Diego
Jul 8, 2005
#12
  • Jul 8, 2005
  • #12
no they are rated at 300ftlbs really weak. The only truly strogner gear set is the g-force kit. All transmissions after 1986 are "world class" its just a newer design.
I
igotyofire
774
Southern California
Jul 8, 2005
#13
  • Jul 8, 2005
  • #13
http://www.ddperformance.com/t5_parts__upgrades.htm
Ak2 2.95 gearset rates it at 330lbs
but here http://www.ddperformance.com/common_ask_questions.htm
it says
Q. Why won't the 2.95 Transmission work in my 1994 or 1995 car ?
A. The input shaft's in the 94-95 cars is 5/8 longer. An input was never made for the the 94-95 cars with a 2.95 first gear.
so im guessing that is not an option for us anyways......
WhiteDevil
2,717
San Diego
Jul 8, 2005
#14
  • Jul 8, 2005
  • #14
it says
Its the same thing if you wanted to put a fox T5 in your car. You would need to switch to a Fox bellhousing and a fox clutch fork and get a DS spacer. Because the fox has a shorter input shaft.
T5 Identification Advice Needed
  • Alldegree
  • Mar 12, 2024
  • 2 3 4
8K
Fox 5.0 Mustang Tech Mar 25, 2024
AeroCoupe
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
J
89 2.3 LX running rich, hesitation on acceleration, high and hanging idle Help!
  • jpstucky
  • Jun 13, 2023
  • 2.3L (N/A & Turbo) Tech
3K
2.3L (N/A & Turbo) Tech Jun 15, 2023
jpstucky
J
