t5 info
cobra42276
I busted up the t5 in my 88 gt with 197000 miles, i'm having trouble finding one, i found one from a ,96 v6 car, i know they are supposed to be weaker, but the torque spec are the same as my early wc , according to my chart. my worry is about the imput shaft length and the trans mount position can anyone please give me some info?
Actually,around 96 or 97 The V6 t-5 was rated at 300 ft'lbs so it may be stronger than yours.
You'll need to change the input shaft and bearing retainer to a fox style. I beleive yours will swap over provided it didn't get damaged
get a junker shelled t5 from a junkyard, should be able to grab one somewhere fairly cheap. get a nice rebuild kit and replace any hard parts that may need replaced. it wont be cheap and u may have to spend a little money, but if you do it right the t5 should be good and last a while
