Drivetrain T5 issues
  • Thread starter Thread starter Carpenter78
  • Start date Start date Apr 26, 2024
Carpenter78
9
Apr 26, 2024
  • Apr 26, 2024
Im trying to get some loose ends buttoned up on my build and need some advice. I found a WC T5 out of a 95 GT to use in my 93 LX. This transmission sat in the previous owners garage for several years without fluid in it. When I bought the T5, I pulled the tail shaft and top cover to do an inspection. Everything "looked" ok except for the fact the internals were dryer than a popcorn fart.
I reassembled everything and installed in my car. The issues I'm having is hard gear selecting. 1-4 is pretty good, but 5th and reverse gear is almost impossible. I can get it into gear, but it is not a smooth transaction.
I was told the transmission might loosen up after some time spend driving. Is there any validation to this advice? If not, what would be causing the 5-R hard shifts?
AeroCoupe
6,162
4,253
183
Claremore, OK
Apr 26, 2024
  • Apr 26, 2024
Off the top of my head would be wrong fluid, bad synchros and/or poor clutch adjustment. If the clutch is adjusted and you are running the correct fluid then it’s time to pull the trans out and break it down for an inspection.
limp
wrap a little cheese around it and its a done
5 Year Member
Oct 4, 2020
5,501
2,922
173
Florida
Apr 26, 2024
  • Apr 26, 2024
Wasn't 94 when ford started using a different bellhousing and the different length input shaft on the T5?
AeroCoupe
6,162
4,253
183
Claremore, OK
Apr 26, 2024
  • Apr 26, 2024
Yes, input shafts and bell housings are different. Swap input shaft and retainer to Fox parts and the T5 is good to go.
That does bring up something else. When this is done you have to shim the input shaft via the retainer. This will cause issues if not done correctly.
General karthief
Mod Dude
Aug 25, 2016
28,059
10,681
213
polk county florida
Apr 26, 2024
  • Apr 26, 2024
Yes but if it shifts and drives then he, swapped the above parts or it was not a 94 trans.
Carpenter78
9
Apr 26, 2024
  • Apr 26, 2024
I did swap the input shaft. I'm running ATF and the clutch is properly adjusted. I'll probably put some miles on it to see if it loosens up. I'm afraid I have something binding on the 5-R rail. I know T5's are fairly easy to rebuild so that might be where it's headed.
Reactions: General karthief
Mustang5L5
Mod Dude
Feb 18, 2001
43,336
18,062
224
Massachusetts
Apr 26, 2024
  • Apr 26, 2024
By any chance do you have a photo of how dry it was inside? ANy appearance of corrosion?
I probably would have pulled it apart to inspect the bearings and blocker rings and the shafts were the bearings ride. It may loosen up as you put miles on it, but my fear is that it may also cause damage in areas where old fluid could be gummed up and preventing fresh fluid from flowing.
Reactions: General karthief and AeroCoupe
Carpenter78
9
Apr 26, 2024
  • Apr 26, 2024
I do not have pictures. When I changed the input shaft, I also put a billet counter shaft support in it. I "inspected" while I had it apart. I was sure to shim counter and input shafts in compliance with a YouTube video by Paul Cangilosi. He apparently is a goto T5 expert. I understand watching a video and performing the work are two different things. I felt good with final assembly and had no issues I'm aware of. A T5 is pretty simple. I will tear it back down if it doesn't get any better. I have only put maybe 10 miles on the car since the build. This has been an ongoing build for 3.5 years and I'm ready to see what I built is capable of.
AeroCoupe
6,162
4,253
183
Claremore, OK
Apr 26, 2024
  • Apr 26, 2024
Paul is a in every sense a SME when it comes to T5’s so if you followed his video the the input shaft and counter support were done right.
Reactions: General karthief and Carpenter78
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Jun 14, 2026
Mindseye007
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
