T5 with AOD computer help
lancec2c30
570
Washington
I have everything together, but I just remembered there are some wires that need to be switched. To prevent the o2 harness from being fried.
I have searched "t5 swap" and couldn't find jack this time. :notnice:
Does anyone know where that ecu pin-out picture is and know which wires to switch?
It's the other way around.
AOD computer will work with AOD O2 harness and t5 o2 harness.
It's the Manual EEC that will not work with an auto O2 Harness. So if you are running the AOD computer and AOD wiring harnesses, you are fine
