Tach mounting locations.
get the tach mounting bracket that modsquad has. no drilling on the dash required and it looks very clean.
scroll down, $44
http://www.holcombmotorsports.com/newproducts5.htm
95Vert said:
I have a buddy who has it on the steering column, but it seems to be too croweded. Michael, that about where everyone has it and have always liked it so I just may install it there. I thought I had seen somebody with it on the left side of the dashboard.
yea i like it there, the only thing is, i wish i hadn't drilled through the dash...if theres a way to mount it without drilling, i would have been so much happier
it goes in between the radio bezel--you drill, but on the inside so it looks very clean and there won't be any visible holes in your dash if you were to take the tach off.
you route the wiring through there, too. check modsquad's out, man, very clean install.
I just put mine on the a-pillar. Its not very subtle, but if I ever want to remove it, I will just have to replace the $21 a-pillar and not the whole dash.
