Taillights..WOW...Duhhhhh
mustangsally93
281
Omaha,NE
Well I putting my taillights back to stock. I need to know what to use to set them in place(noting going to use super glue or something that can't come off) I need something like the gum stuff stock? Also Should I paint the in side silver again? I have mouse homes in both taillights. Also when I took them out of the car I drop one and cracked it. I'm glad I bought 3 pairs off ebay..
So a side note I just got a valentine 1. I love it already!!!
While you have the housings apart, sand the inside silver areas with 1500 grit sandpaper, and spray with chrome spray paint. I did this on mine, and it makes the taillights brighter.
Also polish the outside of the lenses.
You need a new 83-93 TAILLIGHT LENS BUTLE install kit. $20
50resto.com
Part Number: HDW-13450K
http://www.latemodelrestoration.com
This is the butle strips you will need, be sure and set the clips strong, and make sure the butle seals well.
Tie the lense to the housing very tightly with a rope or bungee cords, and let it seal for at least 24hrs.
Rushing these steps will only lead to dumb leaks, and moisture bulidup inside the lenses.
How do I poilish the outside?? I tryed with the head lights but I just melted them:bang: :bang: So I bought new from latemodel. Also just chorme paint from a parts store? or auto paint?
not to hijack the thread but exactly how do you take these apart i dont have any spares and i dont want to f them up, is there clips any tips would be good sally thanks mine are loose and they need fixed
You have to carefully pry them apart, working from the inside towards the outer edges. The clips will actually bend in most cases so new ones are a must, unless you want pre stressed clips holding your lenses on.
People have been known to steal lenses from Fox cars, so I would advise using an epoxy sealant to permanently seal those bad dudes on. Epoxy sealant also ensures 100% leak protection.
Just know that you can't change your lenses after that step.
