  • SN95 4.6L Mustang Tech
TB Whistle
  • Thread starter Thread starter BluThnder99
  • Start date Start date Jun 20, 2004
BluThnder99
201
St. Louis
Jun 20, 2004
  • Jun 20, 2004
Tonight I installed my TFS Plenum and now my TB is whistling. How can I fix this problem?
Ryan02Stang
1,181
Arlington Heights, Illinois
Jun 20, 2004
  • Jun 20, 2004
How bad is the whistle? I get a quick whistle when I first open the throttle body.
BluThnder99
201
St. Louis
Jun 20, 2004
  • Jun 20, 2004
That's exactly what mine is doing. How the can I fix it?
Ryan02Stang
1,181
Jun 20, 2004
  • Jun 20, 2004
Not sure. I think it is normal. I have known several people with my setup and they all have it. Its only when the throttle body first opens...other than that it sounds fine.
BluThnder99
201
St. Louis
Jun 20, 2004
  • Jun 20, 2004
Right thats exactly what its doing, there's gotta be a way to fix, What do you think is causing the whistle?
Ryan02Stang
1,181
Jun 20, 2004
  • Jun 20, 2004
I have no idea. I have checked over and over again for a leak anywhere and there is no leaks. I have checked all my vaccuum lines and nothing. The only explanation I can think of is something internal with the throttle body.
dmarco_4u
194
  • Jun 20, 2004
Turn the music up!!
I have the same thing i just call dont call it a problem. Couple of my friends TFS do the same thing.
01mgvert
302
  • Jun 20, 2004
I installed a Dragon plenum and it whistled upon acceleration, especially around 2000 rpms. I contacted Dragon, and they said that this was common for their plenums. It seems that the divider inside the plenum causes the whistling when it splits the air flow. I found the noise to be annoying so I returned the plenum to Dragon. I then ordered an Accufab plenum and haven't had any problems.
2001Saleen181
193
  • Jun 20, 2004
You could also try re-positioning your inlet pipes. Move them in/out a little to change the length of the air travel. I even turned my maf a little to change the position of the sensor inside. This finally helped me with my whinning noise.
neoclasiccl
3,043
Help I can't see !!!!!!
Jun 20, 2004
#10
  • Jun 20, 2004
  • #10
If you don't like the whistle then you would hate my car. The oval TB and Kenne Bell is very loud.
I dont complain
twogts4us
4,188
12
79
Dunedin, FL
Jun 20, 2004
#11
  • Jun 20, 2004
  • #11
Smart Move!!!
I've heard a lot of people complain that the TFS and the Dragon elbows whistle. To me, that's just poor engineering / design.
The Accufab doesn't make any weird noises.
Drivetrain Engine whistle all of a sudden
  • 01SVT
  • May 17, 2026
Fox 5.0 Mustang Tech May 19, 2026
General karthief
MS3 Pro
  • revhead347
  • Nov 12, 2025
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 15, 2026
revhead347
M
My numbers sound right?
  • MiltP
  • Feb 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 2, 2026
MiltP
M
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
T
2008 GT Parasitic drain - sjb
  • turcotjs
  • Aug 1, 2025
2005 - 2014 S-197 Mustang -General/Talk- Aug 1, 2025
turcotjs
T
