TB Whistle
Ryan02Stang said:
Not sure. I think it is normal. I have known several people with my setup and they all have it. Its only when the throttle body first opens...other than that it sounds fine.
Right thats exactly what its doing, there's gotta be a way to fix, What do you think is causing the whistle?
Turn the music up!!
I have the same thing i just call dont call it a problem. Couple of my friends TFS do the same thing.
BluThnder99 said:
Tonight I installed my TFS Plenum and now my TB is whistling. How can I fix this problem?
I installed a Dragon plenum and it whistled upon acceleration, especially around 2000 rpms. I contacted Dragon, and they said that this was common for their plenums. It seems that the divider inside the plenum causes the whistling when it splits the air flow. I found the noise to be annoying so I returned the plenum to Dragon. I then ordered an Accufab plenum and haven't had any problems.
You could also try re-positioning your inlet pipes. Move them in/out a little to change the length of the air travel. I even turned my maf a little to change the position of the sensor inside. This finally helped me with my whinning noise.
Smart Move!!!
I've heard a lot of people complain that the TFS and the Dragon elbows whistle. To me, that's just poor engineering / design. :notnice:
The Accufab doesn't make any weird noises. :nice:
